Results 1 to 11 of 11
Thread: copper flakes coming from heater
    I am getting a lot of small what appear to be copper flakes coming out of my heater and then into the pool. I figured this may be my heat exchanger going bad so I bought a new one and installed it. Same problem still. Any ideas?
    Heater is a Sta-Rite max-e-therm 400,000 btu
    ph level is kept a 7.70 via autopilot total control system.[attachment=0:2jaqo392]copper flakes.jpg[/attachment:2jaqo392]
    21,000 gal Fiberglass (Indoor)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,418
    Re: copper flakes coming from heater
    Do you have any copper pipes in the pool plumbing?
    Love TFP? Become a
    TFP Supporter!
    None
    Mar 2007
    San Rafael, CA USA
    12,082
    I would have thought it might have been the heat exchanger as well, but since you replaced the heater and it still is happening then clearly it's coming from somewhere else. Do you have a saltwater chlorine generator or a copper ionization system? I'm just thinking of other metal parts you might have that could wear and break apart.
    I definately think it's the heater.... just can't figure out how/where/why. Below is my set-up, pump, filter, heater, salt generator, pool return lines. Right after the water exits the heater it goes through a screen strainer and that is catching the flakes. This is why it must be coming from the heater.
    fyi, the autopilot total control is only being used to control the PH. I had switch back to regular water because the salt water was eating my aluminum auto cover parts.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I wonder if they are just residual flakes from before you replaced the exchanger, that are now working themselves loose from wherever they got stuck...
    30,431
    If there are no more remaining copper parts in your system, MITS's explanation makes perfect sense.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    the picture you uploaded, is this inside a room?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Yes. It's an indoor pool and that's my mechanical room.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Not to get off subject, but do you have the heater exhausting to the outside?
    My guess is that some of the flakes you are seeing since the replacement are residuals that have been floating around somewhere.
    Paul
    Yep, the exhaust is piped to the exterior
