Thread: air bubbels in return jet????
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    when i hook up my vaccuum to the skimmer i get air bubbels comming out of one of my jets and some air bubbles out of the spa return. there is bubbels in my see through cap on my pump also as well as my cartridge filter unit. as soon as i disconnect the hose from the skimmer all bubbles go away and a purge the filter unit and i ahve no more air bubbles anywhere. and i dont loose prime on pump or filter ever.
    so.......could these bubbles be comming from my spa valve where it intakes air for the spa???? or should i be concerned and look elsewhere? no leaks on pump slab.
    please help thanks!!! todd
    Thanks Todd.
    15,000 gal. In ground, sand textured with beach area, spa located in beach area with spillover equal to pool level.Rock waterfall with 4 foot drop.Hayward goldline aquaplus automation all wireless remote.T 15 cell,Propane heater,Super 2 for pool/spa,Super 2 for waterfall.Cartridge filter and solar panels.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: air bubbels in return jet????
    Sounds like a suction side leak that shows up with the increased vacuum caused by your suction side vacuum...or your vacuum hose has a small leak. If it is not the hose, then common places would be pump cover gasket, pump drain plugs, or any connections on the suction side.
