Thread: Above Ground Pool - Return /Winterizing
    Sep 2013
    Ringtown, Pa.
    7
    What is the best way to close off the return line ? The 1-1/2" fitting is a OD threaded all one piece with gaskets & fittings that screw on either side of the pool wall. After I remove the directional ball can I screw on a pvc threaded cap or do I need an expanding rubber plug? I live in the Central PA & winters can be unpredictable and can be mild, freezing rain or snow.
    AG 5800 gal 15' x 52" Round Cameo w/ Hayward S!66T sand filter & SPX1515Z1E 1-1/2 Hp Hayward Power Flo Pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Above Ground Pool - Return /Winterizing
    Welcome to TFP Mr Happy.
    I use an expanding rubber plug. Works great.
    Jeff
    Sep 2013
    Ringtown, Pa.
    7
    Thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    You can use either to plug the return.
    Love TFP? Become a
    TFP Supporter!
    Sep 2013
    Ringtown, Pa.
    7
    I used a threaded plastic cap with an o-ring I picked up at the local pool supply. Thank You
