Results 1 to 16 of 16
Thread: Advice On Upgrading To A More Efficient Pool Pump.
    I have 12 a year old 27K gallon 18X40 vinyl pool with 1-1/2" piping.
    Two returns, bottom drain and two skimmers.
    Hayward Perflex EC75 DE filter.
    Hayward Super Pump 230V Model C48K2N143B1 A.O. Smith 1 h.p. motor.
    PPL electric rate is $0.08777 per kWh.
    I run my pump about 8 hours a day in S.C. Pennsylvania for 4 months/year.
    Sanitize using 12.5% liquid chlorine with injection pump.
    Not sure if I should go with two speed motor or VS. due to return on investment and reliability.
    So what pump/motor would you recommend for this pool.
    Appreciate any input.
    27K Gallon vinyl pool, 1hp 2 speed Hayward Super Pump, EC-75 DE filter, Stenner 45MPH22 liquid chlorine injection pump with timer control. Taylor K-2006 test kit, Aquabot pool cleaner. location SC PA.
    30,432
    Re: Advice On Upgrading To A More Efficient Pool Pump.
    The general consensus is with your electrical rates lower like yours are, the return on investment of a VS pump doesn't work out.
    A 2 speed will pay you back pretty quickly, however, so that would be my suggestion. I have no opinion on brands......they all seem roughly the same quality.
    I also thought the payback on the vs might not be the best option.
    I see that they make a 2 speed replacement motor/with timer onboard for my pump. Now it's about getting the correct one and best price.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    linen edit: I made a mistake specifying a 115V motor. See post below.
    [s:399blz9v]A 2-speed replacement with a integrated timer for the motor you listed is the a.o. smith B973T (aka B2973T). Best price I could find is: http://www.inyopools.com/Products/00...FepFMgoddDcA7g[/s:399blz9v]
    Thanks Linen!
    That looks just like what I need.
    I'll check out all the details about it and start saving some energy next summer.
    Jun 2007
    New Jersey
    653
    This is just my personal opinion but I would think twice about those on-board timer motors. I worry about increasing the likelihood that I am without circulation due to a timer failure. With a separate timer, you can at least by-pass it and control your pump manually from the breaker. If the timer section needs repair, you can send it out separately. I still believe the good old Intermatic mechanicals are the gold standard in reliability and I would prefer to stick with those.
    Also, my impression is that the added cost of the timer equipped motor is no bargain. A separate timer can frequently be had for less, so the savings is in the installation. In my case, this work I do myself.
    I never liked combo VCR/TV's for the same reason. It's just better to have separate components when things go wrong.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Thanks for your input Durk.
    I'll keep that in mind as I continue my research.
    I can do the wiring part so the new timer might be the better way to go and also solve the priming at startup on high speed. The way it looks to me is with the onboard timer the min high speed time is one hour and that's way more than needed for priming. I know it will prime on low speed if no air leaks are present but not willing to take that chance.
    Another thing that concerns me about running at a lower speed is skimming the top. Doesn't this affect the removal of debris because of less suction at the skimmers?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Durk makes a good point.
    Quote Originally Posted by ravenjim
    Some folks run a short time on high a couple times a day to help with the skimming action with the rest of the run time being on low. On my pool, I generally get acceptable debris removal even when I only run on low (except when leaves or maple whirlys are falling)... I get a nice circular circulation.
    I found a B975 1HP motor that has a U56J frame. Anyone know what the U stands for because my motor is just a 56J?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by linen
    Looks like I made a mistake here since you posted 230V (not 115). Sorry about that, glad you caught it
    Yes the B975 (or B2975 or B2975T) is the right motor. It is 56J frame.
    There is one here that is decently priced: http://www.poolsupplyworld.com/Centu...FU1gMgodJl4APQ
    Yeah I caught that. Good price for that motor (975T) but I do like the idea of the mechanical timer being less problematic.
    Just bought a new B975 on Ebay for $175. The build date was 2002 but that shouldn't matter because the motor data was the same as the newer ones.
    Now for a T106R timer. Saw a new one for $84.17 from Smarthome I think I'll get.
    I hope I didn't make a mistake and purchase the wrong motor.
    The one I bought 1 HP (B975) has a service factor of 1.4 and my old 1hp SF is 1.1
    Can I still use this motor on my pump? SP-1607-Z1-M 1H.P. S.F. 1.1
    38,548
    Using a higher power motor on the pump is not a problem.
    The B975 might be an uprated 3/4 hp with a service factor of 1.4 which would make it a 1.05 hp motor.
    Is that correct? because the motor name plate doesn't have it listed as 1 hp but when I google B975 it comes up as a 1hp. and the guy advertised it as a 1hp.
    Hope that made sense!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The B975 has a Total hp of 1.4 and your old motor had a Total hp of 1.1, but as jbliz said, it will work for your pump since you can use a larger motor and should still use about the same power if you went with the B973 (or another 1.1 total hp motor).
    Thanks guys!
    I was a little worried there that I might have defeated my purpose of saving energy by using a higher rated motor but I see now that the pump design will only use a certain amount of HP. from the motor. Awesome!
