Thread: Winterizing above ground pool..PH and stablizer?
    May 2012
    NE OK
    54
    Question: My PH is 8.2+, I should lower that before closing, right? Also, I have next to no stablizer. Is that a big deal in closing the pool? When I opened the pool earlier this spring I had HORRIBLE calcium scaling. I do not want that problem again!!
    My current readings are:
    FC-11.5
    CC-.5
    TC-12
    PH-8.2+
    TA-110
    CH-190
    CYA-0-5
    25,000 gallon
    AG
    Sand
    filter size is 26 diameter
    flow rate 70 GPM
    AG Pool (33ft.) was newly installed in spring 2011
    30,421
    Re: Winterizing above ground pool..PH and stablizer?
    Of course, lower the pH immediately. It should never have been allowed to get that high and is a VERY significant factor for scaling in a pool.
    At this point in the season, CYA is not that important but you should probably read "The ABC's of Pool Water Chemistry" up in Pool School to get a better grasp of normal water parameters to head off issues next Spring.
    May 2012
    NE OK
    54
    Thanks! That's what I thought. I added 64 oz. muriatic acid. I will test it again later this evening. I constantly battle rising PH.
    25,000 gallon
    AG
    Sand
    flow rate 70 GPM
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by curlyfry22
    Looking back at your previous threads, your TA testing is either inconsitent or something is adding TA to your pool. Getting TA down will help a lot with your ph rise. Have you tested your fill water for TA and ph?
