Thread: New Pool
    New Pool
    How much acid should I be adding to get the PH down. It is around 7.8 to 8 now and just wont go down. I hear this is common with new pools. I am probably a little light on th trigger when it comes to adding MA, typically add a cup or 2. Should I be adding more?
    Southern California/sun all day
    26k gal/in-ground plaster/jacuzzi spillway
    dual speed 1.5/2.5 Hayward
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Wife in bikini and Margarita maker
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    Re: New Pool
    Including a full analysis of the pool water would be helpful....especially ALK.
    I would recommend using the pool calculator This is a very easy to use tool that will help figure out the amount of acid you should add. Just be sure to enter the number of gallons in your pool at the top of the calculator. And, since you want to adjust pH, I would recommend adding about on half of the acid the calculator recommends, waiting an hour and testing, then making the other half of the addition.
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    Butterfly's Avatar
    South Carolina
    Re: New Pool
    Hi Sausage,
    Excellent info from NCFlyersFan.
    If you will read this article on the info we need prior to posting, it will help a lot! category/pool-school/read_before_you_post
    This article, along with many others, are found in Pool School. The link to Pool School is located at the top of each page in the sub-heading. Also, link in my sig.
    Welcome to the forum
    You're done SLAMing when:
