Results 1 to 9 of 9
Thread: Ready to take care of the pool myself
    Jun 2013
    Southwest Arizona (Yuma)
    125
    Being a new pool owner can be a little overwhelming. I have learned a lot thanks to this forum in the last 3 months. I wanted learn everything before I fire the pool service and start doing it myself but I am more of a learn by doing type of person. So I'm ready to just do it. I know I need a good test kit but other then that what would you all suggest I have on hand?
    JB
    My pool:
    Built 2004, 14K gal, IG plaster,Pentair WhisperFlo 2 HP pump(1 speed), Pentair FNS Plus DE filter,
    In Floor cleaning system, Attached Spa with Spillover seperate WhisperFlo pump for jets.
    22,537
    Re: Ready to take care of the pool myself
    Really nothing. Get the test kit and once you have the results you'll be able to tell what you need and what action(s) you need to take.
    38,235
    Yup. All we know for sure is that you will need bleach to maintain FC, the rest depends on your test results.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Knowledge is your best weapon to have on hand.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    One thing I would like to add is when you test all your parameters and get everything in range don't micro manage the levels. All the parameters have a range and as long as everything is in range you should be good to go.
    If it's not broke don't fix it !!
    Jeff
    Oct 2012
    Houston TX 77064
    101
    Hey, you can do it - I fired my pool guy just before resurfacing 1 1/2 year ago, so much easier now. Don't forget to brushing, vacuum, and the filter. Follow the guidelines true and sure. Just ask the forum anything, best resource ever - you may be doing it yourself, but you are never alone.
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    Jun 2013
    125
    Thanks everyone, It's very reassuring to know I can go it alone and come here for help if I need it.
    My pool:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    It's not that difficult to maintain once the water is balanced. There's a fairly steep learning curve, but once you have a few weeks' practice, it gets to be routine and boring. You'll know the pool's appetite for acid and bleach, how often to vacuum, what the pump sounds like and what the pressure should be soon enough.
    There's a certain outlay at first for the test kit and the chemicals, pole, brush, vacuum, all that stuff, but it will be repaid in two or three months by not paying a pool service.
    Expect to become infected with sparklypoolitis, as well as Pool Snobbery. You'll begin hesitating to go in other pools soon; it's normal around here.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Congratulations for taking control yourself. You will find it far easier than you once imagined. I want to second Woody in saying that knowledge will be the best tool in your kit.
    Essential Links:
