Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Circupool RJ VS. SI
    Sep 2013
    Bakersfield California
    34
    Circupool RJ VS. SI
    Hi All,
    I have two questions:
    1. I have a Zodiac ML-2 that I would like to replace with Circupool. Has anyone done this and and how difficult is this.
    2. I searched and couldn't find anyone with an SI series Circupool here. They have a promotion now on the SI where when you buy one you get the next level up for free. I was thinking about getting the SI for that reason. Any thoughts?
    CHRIS
    12700 gallons
    IG pool and spa
    plaster
    Sand Filter Pentair Titan II
    Pentair Whisperflo single speed pump WFE 4 (1 HP)
    Built in 2005
    SWG equiped, Zodiac LM2-24
    CH 340, PH 7.8, FC 8.5, TA 90, CYA 80, SALT 4000, CC 0
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Circupool RJ VS. SI
    Quote Originally Posted by cbrown91
    The only difference that is obvious that I can see (other then how they look) is the SI has a 4 year warranty and the RJ has a 7 year.
    Sep 2013
    34
    They are offering the SI-PLUS with a 6 year warranty. The above promotion does apply on the SI PLUS also. So I was wondering if anyone has had one of these installed.
    THX for the response.
    CHRIS
    12700 gallons
    IG pool and spa
    plaster
    Built in 2005
    Oct 2013
    Gulf Breeze, FL
    21
    I ordered a SI-40 and took the upgrade to the 6 year cell, it should arrive to me tomorrow. I don't remember the name that they used, but there are more measurements/accuracy in regards to the chlorine production.
    I'm replacing a Polaris AutoClear Plus which died during the previous owners time.
    14,500 Gallon kidney shaped in-ground vinyl, Pentair Clean & Clear Plus - 420, Circupool SI40+, 1HP - Pentair Whisper-Flo single speed, TF-100 Test Kit, Hydro Spa Lexxus 225 gallon spa. New for 2018 is a Latham "Indigo Marble/Blue Granite" liner.
    Hi All,
    CHRIS
    Hi Chris,
    I don't have a SI series yet but was a recent owner of the RJ45. That was a pretty simple install that took less than an hour and after about 2 years it is still going strong. We just brought a new house that has a pool with no SWG and I will be converting to the Si series. From what I read, the Si series is threaded as a bolt on replacement for the Hayward Auquarite and Pentair systems. I am not familiar with the Zodiac ML-2. If you are referring to the LM2 then you will need to do a little more plumbing to make it work but well within the scope of the average DIY'er! If the SI series is as good as the RJ series you will get years to performance out of it.
    Round AG 17000 gals. Hayward PowerFlo 1 H.P. 60gpm Sand Filter Aqua Smarte Cannister Chlorine Feeder
    Oct 2013
    Chapin, SC
    1,141
    Why isn't this thread showing up on the thread list?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    cbrown91, the SI and SIplus are both rather new, thus there has been relatively little experience with them.
    timerguy, where are you looking? It shows up just fine on the SWG thread list.
    Oct 2013
    Chapin, SC
    1,141
    It wasn't until I posted that post! And your reply to rarenomad, what was that in response to? BTW, I talked to someone at Discountsaltpools today and he said there's an upgrade sale going to start on Wednesday. So anyone interested in getting say a Si-45 for the price of a Si-30 (presently $649) can do so starting Wednesday. I really don't think the 7 yr prorated warranty is worth $100. And the Vector Jets can be bought for $10. That's all I can see is what you get for getting the + models.
    Regarding rarenomad--disregard I see his thread I posted on earlier!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    No need for vector jets.
    Quote Originally Posted by timerguy View Post
    Wow this is great news, I may go the 30si non plus (then being upgraded to the 45)seeing as the consensus for the jets are not needed. That will save me $200! If this works out, I will be thrilled!
    Brian, Pool newbie in Atlanta, GA. 24k IG vinyl pool, Circupool SI-45 SWG (purchased 3/2014) , Hayward Pro Series Sand filter S220T, Pentair 1hp 2-speed superflow (thanks Jbizzle!), TF-100 test kit w/ SpeedStir
    Removed -> Hayward 1HP Super pump SP-1607-Z1-M
    Also should mention that the claim to the plus in addition to the elevated warranty is that the cells will operate for 15k instead of the non si-plus rated at 10k
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by bobodaclown View Post
    Sent from my AT100 using Tapatalk HD
    Yeah, I didn't think so!
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by rarenomad View Post
    Sent from my Nexus 10 using Tapatalk
    I'll let you know when I talk to the guy tomorrow. He's going to call me around 10am.
    Hehe see if we can get free shipping lol. Thanks mate!
    Oct 2013
    Chapin, SC
    1,141
    Since I can't find the "real" specs for either model, I can't be sure of the claim that they're different. I suspect they're not, but I'm going to find out. I did find the costs for OEM replacement cells for each--guess what the price difference is!
    Exactly the same? Heh
    Oct 2013
    Chapin, SC
    1,141
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    I seriously doubt they would engineer a different cell for two models that are essentially the same. I talked to compupools this morning. Their cpx 36 is rated for 12,500 hrs and and she told me their chlorine output is .92/day. I'm still waiting for Jason to explain why he says circupools claim of 2.0 is not correct in a different thread. Still waiting for the guy from discountsaltpools to call me. I did the numbers of the hrs claim. 12500 hrs at 8hrs/day is like 4 years
    Update: just got off the phone with discountsaltpools. He says the titanium plates are thicker and will last longer. The expected lifetime for the Si-45 is 10,000 hrs which is about 3.5 yrs with 8hrs /day runtime. Now I'm in a quandary over which one to get. $30 shipping from discount salt pools.
    Made my decision--Getting the Si-45 -- $679 out the door!
    Aug 2011
    Oldsmar, FL
    34
    Wouldn't your calculated run time probably be around 50% of what your pump run time is? Especially if you're over-sizing the unit for your pool size? So if you're running your pump for 8 hours per day the SWCG run time would be about 4 hours. Those of you that have had your units installed for a few years, what % do you typically have it set at and are you oversized for your pool size?
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    80% in may, june, july, august, running a RJ-65 Circupool in Texas with a 30,000 gallon pool 8 hour pump run time. Gives my 5 ppm chorine all the time.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
  20. Back To Top    #20
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by Seanhan View Post
    Sent from my iPad using Tapatalk
    Curious, what do you run it at in other months?
