Results 1 to 18 of 18
Thread: Upgrading from intex 2650 pump/filter discussion
    Oct 2013
    Los Angeles, CA
    87
    Mod Edit: Split from this topic. Question in this post was in reference to the Hayward Matrix 1 hp 2-speed pump.
    did your 2 speed pump move enough water in your pool?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Hayward Power-Flo Matrix 1hp 2 spd? Question about pump.
    I've got the same pump. I run on low speed for 6 hours a day for general filtration. I'll use high speed for about 2 hrs when I dose with bleach and to get better skimming of stuff floating on surface.
    As for your water feature you'll have try and see how it works on low.
    Jeff
    Oct 2013
    Los Angeles, CA
    87
    Re: Hayward Power-Flo Matrix 1hp 2 spd? Question about pump
    So on low speed it moves a good amount of water ? Is your pump hard plumbed if so how far away from the pool is your pump ?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Hayward told me told me about 20 - 30 GPM on low. Whether or not this is true I don't know. On high speed it moves some water. Mine is not hard plumbed as of yet.
    Jeff
    Oct 2013
    Los Angeles, CA
    87
    I want to hard plumb my 12 by 24 intex but i am worried the hayward 1 hp 2 speed will not have enough power to move water. I plan on adding a throw the wall skimmer and an eatra return
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by florentino
    Quote Originally Posted by pwrstrk
    It entirely depends on the plumbing. In my 1.5" hard plumb case, I get about ~20 gpm on low. I run on low almost all the time, except when my solar panels are in the flow loop.
    Oct 2013
    Los Angeles, CA
    87
    How far is your pumbing run ? Return and intake
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You can get all the detail of my plumbing here, when mas helped me analyze my setup for running solar panels: http://www.troublefreepool.com/solar...0.html#p358890
    Bottom line, this pump moves a lot of water...if anything, it might be a little overkill for your pool. The pentair dynamo model 340203 is a 2-speed that has a little lower flow than the matrix.
    Oct 2013
    Los Angeles, CA
    87
    So ypu would consider it over kill even on low speed ?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Less overkill on low, but still likely more than you need on your fairly small pool. Your current pump/filter should be well sized for you pool. If you are having trouble with it, start a new topic with the details.
    Oct 2013
    Los Angeles, CA
    87
    Arighty thank you so much for all the great advise. I am planning to upgrade to hayward s 24 sand filter and two speed pump to save on electric bill
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The filter of the Intex 2650 sand filter/pump combo (that is the one you have?) is correctly sized for your pool (although going bigger is not a bad thing). As for the pump, it is a 0.95 hp motor, but only has a service factor of ~0.5, making it "equivalent" to ~1/2 hp up-rated motor in the industry. It likely is not using much more electricity than the low speed of the lowest hp 2-speed agp pumps available. Have you measured how much power it is using? It is said "if it ain't broke, don't fix it" or in this case maybe it is better to say "fix it (replace then?) when it breaks".
    Oct 2013
    Los Angeles, CA
    87
    i have not measured the power consumption but i saw on this forum that the intex draws about 5 amps. and yeah i do have the 2650 intex. Compared to the low speed of the hayward 1 hp only draws 2.9 i belive.
    I wanted to upgrade because i had to back wash serval times this season but it was due to alge problems. I will be putting the Aqua trol in my pool for this upcoming season and do not want to constantly be back washing and getting ride of the salt in the pool.
    Does the reasoning make any sense? lol you help is very appreciated thank you
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Could you point me to where it shows that?
    Sounds like your problem is water chemistry and not filter related. I am going to split off this thread and make a new one so we can discuss this more.
    Oct 2013
    Los Angeles, CA
    87
    Re: Upgrading from intex 2650 pump/filter discussion
    okay here is the link to the intex amp draw hayward-power-flo-lx-pump-and-16-sand-filter-vs-intex-2650-t48218.html
    last season i did have a problem keeping chlorine in the pool which lead to alge problems
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That doesn't look like they measured it, but I am not sure.
    With that said:
    • Intex 2650: for a 5 hour run time (probably more than you need with the 2650) at $0.25/kwhr (just guessing since you are in cali) it would cost you $0.71/day (just using rough estimates of 5 amp X 115 volts = 0.575 kw)
      Matrix 1 hp 2-speed on low: for a 5 (25/20)= 6.25 hour run time (I assumed about 25 gpm for the 2650 and about 20 gpm for the matrix on low), that would cost you about $0.52/day (just using rough estimates of 2.9 amp X 115 volts = 0.333 kw)
    So the difference per day in cost would be ~ $0.19/day
    The equipment you proposed:
    • Matrix 1hp 2-speed $250
      S244T $350
      Resale value of intex 2650 $100
      Net Total: $500
    Assuming you keep the pool up 365 days a year, the payback would be 500/0.19/365 = 7.3 years
    In all actuality, you likely could get by with less run time, especially in the cooler months, and it sounds like you do not run all year...so much longer payback. Also, the current values used above are likely ratings and not real world numbers.
    Nope, I wouldn't do it until the intex breaks.
    This can be fixed, and is probably the real source of your desire to move to a new pump, but if you don't have it, you should get an appropriate test kit so that you can maintain your pool chemistry correctly. See: http://www.troublefreepool.com/pool-...kit_comparison
    Oct 2013
    Los Angeles, CA
    87
    thank you so much for you help i think i will put off getting bigger equipment until i have an actual reason too do so.
    One more question if i could get my hands on a bigger filter i could just run it with the intex pump right?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would just use the intex filter for now, it is properly sized for your pool volume and any excessive backwashing should be eliminated with proper pool chemistry.
