New build - Fort Worth, TX
clw72
Oct 24, 2013
67
Fort Worth, TX
My husband and I moved into this house late June 2013 knowing we wanted to put in a pool within a year. After talking with a couple of PBs we decided this time of year is ideal, so here we go...
Some before pics:
an image of what we have planned, except we've already made one change request and that is to put flagstone on the tanning ledge
Our PB surprised us last night with an email saying they would be starting our dig today. It rained off and on all morning and finally around 11:30 they pulled off the project. We have two dump trucks & a trailer parked on our street, a bobcat and a track hoe in our back yard, along with A LOT of mud. But that's okay, it'll all be worth it in the end! :-D
linen said:
Looking forward to your build!
Post some pool equipment details and we can make suggestions to help you avoid common mistakes.
Thanks Linen. Here's the rundown:
Hayward Tristar 2HP 2speed pump
60ft2 D.E. filter
ProLogic PS4 w/freeze guard
Hayward Aquarite Salt System
Polaris 280
Would love any suggestions or comments regarding the equipment.
Today turned out to be windy and sunny, so they were able to come back & complete the excavation. Plumbing & steel are scheduled for tomorrow!
That is a big pump as needed for the spa I suppose, but at least it is a 2-speed for when not using the spa. And the filter is a good size :goodjob:
The 280 requires a booster pump, was that not listed on the invoice?
There are other pressure side cleaners that do not need a booster (like the 380). Or there are suction cleaners or electric robots.
What size Aquarite cell? You should get the T-15 (40k cell) and not the 25k cell. It should just plug into and be controlled by the PS4.
cal-hypo is just one form of chlorine powder, but you have to be careful that you do not let the calcium levels in the pool get too high:
ABCs of Water Chemistry
Recommended Pool Chemicals
How to Chlorinate Your Pool
Good to know the filter is a good size. I'm still learning about all this and have been putting a lot of trust in the PB.
Seems like I remember him saying it would have a booster pump, but it's not listed on any of the paperwork...will be emailing him tonight to make sure. Will also ask him what size Aquarite cell.
Thank you so much for all the info! Helps me feel like less of a doofus. :hammer: :wink:
Is it common to have both a salt cell and cal-hypo oxidizer? Would you advise not using the oxidizer and just relying on the salt cell for chlorine?
I think you mean the 360. ;) The 380 still requires a booster pump.
Other than that you're spot on!
If you have a SWG and maintain adequate FC, there is no need for cal-hypo. It is just a powder and not sure why it would be listed on the invoice ... that seems odd and would suggest getting clarification.
cbink said:
For startup maybe?
Yes, I checked with the PB and the cal-hypo oxidizer will be used for start up. Seemed weird it was listed under equipment on the spec sheet. Kinda confused me for a bit.
All the steel and plumbing was done on Friday. The electrician came Saturday to ground the pool so gunite could be done Monday. Rain is in the forecast tomorrow through Wednesday, hopefully that doesn't mess up the schedule.
We asked our PB if we would be able to dim our pool light. He said they don't get a lot of requests for that, but to talk to the electrician and he could probably get it done. We did and he's going to put in a dimmer switch for us. So, do most pools not have a dimmer for the light? We had one in our previous pool, and we used it A LOT.
The last pic I posted was plumbing and steel. I have a lot to post...
Gunite day
Not sure why they put the plastic sheeting around the perimeter.
It rained a day or two after gunite, so there were a couple of days of no work.
Rock crew came and did the moss rock water wall in one day:
The coping and tile crew worked for 3 days. Cutting and chipping flagstone does not look like much fun at all. Plus the dust coats everything within sight. How these guys don't work with a mask on at all times is beyond me.
Amazing how just the forms for the decking makes such a big difference.
We were gone for 3 days and during that time, the decking was poured, the final grade was done and the sand was spread out for the sod. Very happy with the way it's looking:
This is the only thing I'm not real happy with. Didn't realize the spillway would be left a smooth cut and the PB says I may not like it if its chipped. We will see...
Plaster was scheduled for this Friday, but there's a 70% chance of rain, so it has been rescheduled for Dec 2.
Carman - it's funny your PB said you wouldn't like it chipped - my spa spillway was supposed to be smooth but my PB said it would be better chipped! I guess it's just a matter of taste. Your pool looks great, glad they got your decking done before all this rain - I'm going to have a huge mud pit!
