Page 1 of 22 123411 ... LastLast
Results 1 to 20 of 435
Thread: Another pool north of Dallas
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Thanks to all of you I'm learning a lot about building and maintaining pools and we are getting close! Would you mind taking a look to see if we are on the right track? Anything we need to change/add/reconsider? I'll try to add a photo.
    21x34 in ground salt water pool
    Pebble sheen finish
    463 sq ft
    89 perimeter
    2 anti-vortex drains
    18x38 bi-level spa - 18 inch height
    2.0 hp blower
    Fountain line and 2 drains for the spa
    Pentair Intelliflow 3050 vs+svrs
    Pentair DE Filter
    Nature 2 Fusion w/chlorinator
    Polaris 280 with.75 hp booster pump cleaner
    3 standard lights
    Bull nose cast concrete coping
    2 in pool benches
    Tanning ledge with gusher
    3 12-inch stone scupper waterfalls
    2 skimmers
    Freeze guard
    Volleyball sleeves
    848 sq ft of decking
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Another pool north of Dallas
    Quote Originally Posted by Readyforapool
    Dump this and just go with a straight saltwater chlorine generator (swg). No need for copper in a properly chlorinated pool. It can stain and cause blond hair to turn green.
    Pentair DE Filter
    Assuming your pool is rectangular and averages 5 ft depth (is this right?), it is a volume of ~26000 gallons. We would recommend a minimum 72 sq. ft. DE filter (I can give you minimums for the other filter types if you want) for your pool.
    Sep 2013
    DFW metroplex
    738
    Hoping this worked.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is probably smaller than the volume I calculated. Is the 21' the widest point? Does the 34' include the tanning ledge? How deep are the shallow and deep ends?
    Sep 2013
    DFW metroplex
    738
    Linen - free form pool 3 1/2 feet to 6 ft deep. The filter quoted is a 60 sq ft Pentair DE.
    Sep 2013
    DFW metroplex
    738
    That's correct 21 ft at the widest point and it's 34 feet in length including the tanning ledge
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Then I would guess you are closer to 16000 gallons and we would recommend a minimum of 44 sq. ft. DE filter for that pool...so the 60 should be great!
    Sep 2013
    DFW metroplex
    738
    17,363 gallons according to the estimate.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Then 48 sq.f.t minimum DE filter
    Sep 2013
    DFW metroplex
    738
    Great thanks for the advice. I'll talk to him about the swg in lieu of the nature fusion system.
    Sep 2013
    DFW metroplex
    738
    Signed the papers - permits will be in the works and hopefully will start digging in about 10 days! Had a hard time deciding on finishes - any recommendation - wet edge vs pebblesheen?
    Sep 2013
    DFW metroplex
    738
    Having two trees cut down today to make room for the pool - the squirrels in the 'hood are going to be so disappointed that the pecan tree will be gone! It was cheaper for us to have an independent company cut them to about a three foot stump than have the PB do it.
    Sep 2013
    DFW metroplex
    738
    Just got a note from Mr.PB - dig should start Tuesday barring any weather issues. Still have some decisions to make, so if you have any suggestions, let me know.
    Pebblesheen blue granite vs Wet Edge quartz Barbados
    Brushed concrete vs aggregate
    Bull nose cast stone vs lueders flagstone with chiseled edges
    Sep 2013
    DFW metroplex
    738
    We haven't started yet but and some would call me a worry wart, I prefer to referred to as an expert planner! Any recommendations on landscaping around the pool? It's got to withstand the crazy Dallas weather, weeks of 106 in the summer, below freezing in the winter, hail storms, tornados and torrential monsoons! How's that for diverse weather conditions? Plan on doing this ourselves, btw.
    Sep 2013
    DFW metroplex
    738
    Mr. Pool Builder just stopped by to check the site and confirm the dig starts tomorrow morning! I walked around over the weekend and let the neighbors know to expect the noise and apologize in advance for the trucks that will block the alley! Camera is ready!
    So excited for you! Can't wait to see pics! Congrats!
    7500 gallon/ 64 perimter ft/ 24x12 "spool" (small pool) :) /18" raised spa with 6 jets/ Ocean Blue Pebble Sheen/ OK flagstone coping/470 sq ft seeded decking
    DE filter-60/2hp2sp pump/Polaris 280 cleaner/2 hp booster pump/Clorinator-in line feeder/Hayward 400k BTU heater/2 skimmers-5returns/Aqualink PS8 wireless controls
    Sep 2013
    DFW metroplex
    738
    They arrived at 7:30 this morning and started digging! Freezing cold this morning with horrendous winds! My hat's off to these guys.
    Sep 2013
    DFW metroplex
    738
    Done - for today!
    what pool builder did you end up with?
    28000 gallon IG pool, 3.5ft - 8ft deep, Stonescapes Tropics Blue Interior, Pentair Intellichlor SWG, Pentair Quad DE 100 filter, Pentair Intelliflo VS-SVRS, Whisperflo 3hp (water features), A&A Max in floor cleaning, Pentair Easytouch 8 Automation, Screenlogic II, Pentair Mastertemp 400k BTU heater, Pentair Intellichem with acid injection via stennar pump, 9'x7' spa with Infiniti edge
  20. Back To Top    #20
    Aug 2010
    Dallas, TX
    4,052
    My wet edge remodel started today... I'm curious, do you know if Romo Plastering is doing your install?
