Thread: Programing Dig-220 with 2-Speed pump
    Sep 2013
    Buffalo,NY
    64
    I had another thread on wiring the Dig-220 with a 2-speed pump and got good feedback. I plan on using the pump relay to control high/low speed with the autopilot but using a timer to control on/off periods. My questions deal with how the autopolit controls the programing.
    I want to set the timer to run the on/off cycles in low and then just use the autopilot to change pump speed manualy for when I need to vaccum.
    To get to this I assume I just set the autopilot as using an exteneral timer in the intial set-up menu. Would that take care of everything? Or am I just better off not using pump relay and installing a seperate switch to control pump speeds?
    There installing liner today so any help is greatly appreciated.
    Thanks
    Daren
    DRB
    16x32 20K IG vinyl, Hayward Pro Grid DE4820 w/ 2-speed 1.5HP Hayward TriStar pump with a .75HP impeller installed, AutoPilot Digg-220
    Ft Lauderdale, Florida
    1,455
    Re: Programing Dig-220 with 2-Speed pump
    drb, if you set up the DIG-220 for 2 speed pump, but do not program the PROG1 or PROG2 timers, you will then use the PUMP button to switch between high speed and low speed.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Sep 2013
    Buffalo,NY
    64
    Thanks for the help Poolsean.
    As an example, would I then just set my timer for 8hrs and experiment with a % on till I get the correct FC? How would boast be affected?
    Again Thanks
    Daren
    DRB
    1,455
    Correct. Boost will only stay on 100% during the timer on cycles. So at 8 hrs/day run times, it will stay on Boost for the next three days.
