Thread: Auto Cover water levels
    The pool company closed my pool last week. They normally leave my water levels about 2/3 - 3/4 up the skimmer but they said they were doing it different this year and drained water to just below skimmer. I asked if the cover would still support the weight of snow and they said it would still be resting on water. They said they didn't fully trust the gizmos any more so that is why they changed it. Does this sound ok? Thanks!
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    Nov 2011
    Moberly,MO
    1,010
    Re: Auto Cover water levels
    Without knowing your general location that is a tough question to answer. In Missouri where I am we close about 150 pools. Almost every one has either an Aquadoor lid or a Skimmer plug with a Gizzmo. We do not drain water down, we leave them at operational level. I personally wouldn't want to drain a pool with a cover on it, kind of defeats the reason of having a cover.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    I think it's good to note here for others that the option to not lower water in areas where it freezes does not apply to gunite pools (AFAIK). The tiles will likely pop if the water is not lowered. No problem for vinyl and fiberglass so long as the skimmer is properly sealed, etc.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Sorry, I'm also in Missouri and this is the first year they lowered the water below the skimmer. they put the gizmos in too but said to be safe they were lowing the water this year. I'm just worried my cover will sag too much and become damaged.
    Jeremiah Hough
    Nov 2011
    Moberly,MO
    1,010
    We have used gizzmos for a long time and as far as I know we have never had an issue with them. Personally I would want the cover supported as much as possible. We had a doctor that once the pool was winterized he never looked at the pool til spring. Cover pump quit working one big snow fall and the weight pulled the track off the deck and cover into the pool.
