Results 1 to 8 of 8
Thread: conduit from concrete deck to equipment pad (bonding)
    Mar 2013
    San Jose, CA
    25
    Hi all,
    I have all my bonding around the pool in but I'm wondering how to handle the conduit containing the bonding wire from the pool to the equipment pad.
    Do I embed the end of the conduit within the concrete and run the bonding wire through it before the concrete is poured?
    Do I let the bonding wire come out of the poured concrete and put the conduit next to it such that you can see the bonding wire come out of the conduit?
    Something different?
    thanks,
    Steve
    14x28 Hydra Pools vinyl pool. EasyTouch, my own web interface (Screenlogic died), Intelliflow VF, 3 Pentair GloBrites, Pentair Master Temp heater, Hayward DE filter. 89" fiberglass spillover spa
    38,284
    Re: conduit from concrete deck to equipment pad (bonding)
    I thought the bonding wire was supposed to be in contact with the ground, not in conduit ... but this is a subject I am unclear about.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is my understanding as well.
    Mar 2013
    San Jose, CA
    25
    Hmm, My electrician suggested a conduit to protect the bonding wire from the concrete decking to the pool pad. Maybe that's why I can't find any info about the conduit.
    Steve
    38,284
    Well the concrete decking around the pool needs to be bonded as well ... will it have rebar in it and is that connected to the bonding grid?
    I suppose if everything that needs to be bonded around the pool is, then maybe you could run it in a conduit to the edge of the deck and then continue on through the ground.
    Dec 2009
    Central Massachusetts
    2,690
    No conduit for the bonding wire, just bury it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Apr 2013
    Sacramento, CA
    2,769
    Code calls for bare wire to be burred 4 to 6 inches below grade. Do not place in conduit.
    The idea is that the bonding system will pick up any stray current in the area and make sure everything has the same level of current. In one sense its the opposite of insulation.
    Mar 2013
    San Jose, CA
    25
    Thanks!
