Results 1 to 7 of 7
Thread: Need opinion on construction issue, out of level
    I can't stop stirring about this problem. I need some suggestions.
    My inground 36x18 x 8' deep end liner pool has been installed, and as the water was filling it was noticeably out of level.
    When it was completely filled I measured 1" low on one deep end corner, 3/4" on the other deep corner, and 1/4" low on the one shallow corner. The other shallow corner is the highest part.
    The liner has printed tiles, and it really makes the level issue look worse.
    The builder is looking at shimming the plastic walls and raising the coping to re-level.
    The deck has not been poured yet so that's good. Unfortunately, the return jets and skimmers have all been cut in.
    I don't see how this repair is going to work without distorting the liner.
    Any suggestions on how to take care of this properly?
    I've spent nearly 30k so far on this project, and this was supposed to be my great investment for my family home. I feel like my savings was blown!
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Re: Need opinion on construction issue, out of level
    That does suck. Honestly, leveling the liner track if properly done won't be a problem but I would tell the builder he owes you a new liner. If the liner is going to be stretched an inch between a return and the liner track it will be weakened quite a bit.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    30,421
    A decent compromise that might not impact the liner at all would be to split the difference.
    Make the lowest corner come up 1/2".
    1/2" out of level will be difficult for anyone to see and would not compromise the liner stretch at all.
    Out of level is not right but 1/2 " out of level I would consider acceptable if the visual impact was not too much.
    Quote Originally Posted by diyindux
    Good point. I need to have him write up an agreement to warranty the liner in the respected stretched areas.
    Yes, we've agreed to 3/4". It's actually a bit over an inch, ~ 1-1/8"
    Your a very nice person. I would not be too willing to compromise with a professional on pool elevations. I built my own pool and it's within 1/4 inch.
    Hopefully he will throw in some extra chemicals or something else to make up for it. You are saving him some money.
    Well the problem is, what other solution is there? Tearing up the whole thing and removing the concrete frame base?
    Trust me, I'm really frustrated with this. Being a master tradesman myself, I put in 110% at my job and I expect perfect, but realize that only happens if you do it yourself.
    It really surprised me that no plumbing pressure testing was done. I had to make a rig and test it myself.
    I thought $28k deserved a bit more attention to detail.
