Thread: Polaris 380 tail stuck in Drain below skimmer
    I hope you can help!! The tail of my Polaris 380 is stuck in the drain hole (I guess it is called a drain) located below the skimmer on the wall. The tail is sucked in about 1/2 way. I turned off the filter and tried to pull it out but had no luck. Any suggestions? The pool is cold, but if I have to jump in, I will.
    Thank you!!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Re: Polaris 380 tail stuck in Drain below skimmer
    Nevermind - I got it out!! I had to get in the pool and just keep wiggling it until it came out.
    East TN
    Raypak Gas Heater
