Thread: Connecting the crawler hose to the suction port
    Hi,
    Have a new crawler, and am trying to connect the 1.5" hose to the suction port. Hose too big, port too small
    Am thinking to get a adapter to sleeve down the hose to 1.25". Any thoughts on where to get/best adapter?
    Thanks!
    x gallon
    IG, pebble-Tech
    Jandy DE filter
    x HP pump
    Installed 2007
    Spa and swim jets
    Mar 2012
    Tampa Bay, Florida
    166
    Re: Connecting the crawler hose to the suction port
    You'll probably have to check out a pool store for the adapter. I have seen people take a section of 1-1/2" hose and put a slit in part of it to force the slit end into the smaller hole. That might be considered a temporary solution.
    Generally, a well stocked pool store will have these adapters since what you have is pretty common.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
