Results 1 to 7 of 7
Thread: salt water system withvariable speed pump
    Jul 2013
    western new york
    62
    Just recently had an fiberglass IG pool installed. Next spring I'm considering installing a SWCG; the question I have is what systems will produce chlorine at low flow rates? I have a variable speed pump (Maxflo VS) and like to run the pump at low speed (1000-1200rpm) for long periods of time as opposed to higher pump speeds for shorter lengths of time. At lower speeds my flow rate is ~20-25 gpm. Any salt systems out there that will produce Cl at that flow rate? Thanks in advance for any suggestions.
    15k gal inground Viking fiberglass pool; Hayward Variable 1.5hp pump (Maxflo VS); Hayward swimclear 325 sg ft cartridge filter; Raypak 206A 199k btu nat gas heater; Aquabot Bravo robotic pool cleaner
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: salt water system withvariable speed pump
    A lot is based on how efficient your plumbing run is to pump and through your filter. With my Pentair vs and the matching Intellichlor IC -40, I can only bring my rpm down to about 1300-1400rpm. Anything lower and I get the low flow warning.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jun 2011
    Long Beach, CA
    2,781
    Pool Pilot claims it only needs 15 gpm to operate.
    Jul 2013
    western new york
    62
    Just spoke with somebody at compupool this morning. He said, compupool units are not flow rate dependent, but only require the cell to be full of water. I would imagine should your pump fail the unit would probably fill with Cl gas which, would in turn, displace that water in the cell causing the unit to shutdown
    Jun 2011
    Long Beach, CA
    2,781
    Search the forums about CompuPool SWG's. They are having some problems with their units right now. I'm not sure I would want one of those at this time as people are having troulble with warranty claims and such.
    JoshU's Avatar
    New Orleans, LA
    542
    Correct. We have seen a large increase in the amount of variable speed pump installations over the past 18 months or so. I've had many customers switch to AutoPilot because of the 15 GPM requirement vs. the higher amount required by other systems.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Ft Lauderdale, Florida
    1,455
    Just helped another TFP member with a similar situation. Got her pump to run at 1000 rpm with the AutoPilot system.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
