Results 1 to 7 of 7
Thread: How hard is it to install a Pentair SWG
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Hi - I've got a full pentair set up - easytouch controller, intelliflo pump etc. I'd like to install a pentair SWG. I think I'll need to install a transformer also.
    How hard of a job is this if I did it myself? I have tackled simple wiring jobs and plumbing jobs in the past. All the components are easily accessible.
    Thanks
    Richard
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    38,475
    Re: How hard is it to install a Pentair SWG
    If you have some PVC and electrical experience it should be pretty easy to install. I am guessing the hardest part will be reprogramming the Easytouch to control the SWG.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    I guess you have to define "electrical experience" I've installed a ceiling fan or two. But that's about it.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    I'm thinking that I might try it over the winter. Worst outcome (apart from electrocution) is that I have to pay someone to finish the job
    38,475
    Are you sure there is a transformer involved and it is not already built into the Easytouch?
    For my Hayward SWG, I just had to cut the PVC and install the cell (and a flow switch, I think the Pentair's is integrated) and then plug the cell into the Pro-logic (and attach 2 wires for the flow switch) ... I would not even call it electrical work honestly.
    Yours may be that simple. Or you may need to install the transformer, which I would assume is pretty plug and play as well, but I am not that familiar with the Pentair automation hardware (or how to change the settings to control the SWG).
    Mar 2011
    Houston, Texas
    413
    My Easytouch did not come with a transformer, but some models do. Double check yours and it might save you some $$.
    Although I have Pentair equipment I went with the AquaRite SWG and I did the electrical myself-it was very easy, and at the time I didn't trust my PVC skills so I had someone do the PVC work. After doing a little PVC work since then it would be a piece of cake. This is definitely a DIY project if you've installed a ceiling fan or two. Just make sure the power is off at the breaker before you start touching any wires.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Quote Originally Posted by HouTex
    Thanks - I am definitely going to do this...
    Why the aquarite over the intellichlor?
