Thread: Hi from Conroe TX
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    Hi from Conroe TX
    Just signed the contract to a brand new gorgeous home in Conroe TX.
    Looking for a good, reliable, reasonably pricing, high quality pool builder.
    Rik
    See my POOL!
    Free form pool, 128 ft perimeter, max length 42ft, max width 38.5 ft, depth 3.5 - 8ft, Chilean Beach Gold Pearl Matrix, 13 ton moss rock waterfall, tanning ledge with 3 gushers, PV3 i, LED underwater lights, automatic water leveling system, 1424 sqft deck.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hi from Conroe TX
    Welcome to tfp, s9601694
    Spend some time searching the "Under Construction" section of the the board...there are a ton of Texas builds ongoing and being documented on the board right now...I am sure some are near the Houston area (Conroe's close to that isn't it?).
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    OK thanks, and yes, Conroe is just north of Houston!
    See my POOL!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Like linen said, check out the Under Construction forum for the latest pool builds. Here's one in particular from Cypress, TX: New build, Houston (Cypress), TX.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes indeed, there are lots of Texas Pool builds here all the time. Welcome to TFP!
    Essential Links:
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    Thanks y'all
    I'm currently working with 4 pool builders. I made a pool design myself and sent it out to them. That way i know i am relaying what we want. They're starting to come back with pricing and frankly, I am presently surprised up to now!
    See my POOL!
