Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: New pool owner, previous tech let an algae bloom,rehire?
    Brand new to pools, so learning a bunch (and very overwhelmed), but here's the story. I bought my home on 9/30, and a week later took my water sample to Texsun Pool to get analyzed. They were stunned at the Chlorine level, and we eventually found out that there was an algae bloom and the pool was super chocked. (texsun even asked if it was a salt pool because of presence of salt, but this is a Chlorine pool and always has been to my knowledge).
    Here we are on 10/24 and the chlorine level still hasn't gone down.
    So I bought a Taylor test kit, and have been struggling to comprehend everything (maybe I'm just dense), but I'm still open to having someone manage the chemistry for me.
    Would you hire the previous technician if they let the pool get to where it is now?
    ~12k gallon, cartridge filter, IG, plaster, 2hp Pentair Whisperflo WF-28, 150gpm filter
    Pics: http://imgur.com/a/HqaPq#0
    22,551
    Re: New pool owner, previous tech let an algae bloom,rehire?
    Welcome to TFP.
    Which Taylor kit do you have?
    How do you normally chlorinate your pool? (tabs, Liquid, Etc?)
    If tabs, are there any in the feeder?
    The short answer to hiring the pool guy is no. BUT, I wouldn't hire any pool guy! You're much better off learning to take care of your pool yourself.
    You have come to the right place to learn to do that, so you're off to a good start.
    Let us know what kit you have and post a set of test results from it and we'll go from there.
    Thanks for the warm welcome. I realize I need to add more details to my profile - I'll work on that today.
    I have a Taylor K-2006 Complete (FAS-DPD chlorine) kit.
    My pool has an inline tab feeder, and at the moment there are no tabs. After testing the water a week after I moved in, with chlorine levels being so high, I checked it and it was empty. I haven't added any yet.
    The pool has visually remained gorgeous though, very clear. I know the chemistry is way off though.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, casastevo
    As Bama said, please post a full set of test results from your kit: FC, CC, ph, TA, CH, cya.
    I too, wouldn't dream of paying someone for something that is very easy to do (using the methods taught on here)...and you already have the right tool (k-2006)!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Stevo.
    We can help you learn all you need to know and understand whatg is gong on in your pool. It can seem like a lot to learn, but if you take it slow and take small bites as you go, it really is quite simple. Free Chlorine, and pH are your two most important parameters to learn about and control first. Take a look at the ABC's of pool chemistry (link in my signature) and start there. Like the old addage walk before you crawl. None of were born knowing this stuff, so don't be overwhelmed with all the information out there, just take it in as you are comfortable. Ask questions, and let us know how we can help.
    Essential Links:
    So I'm in the middle of trying to find the FC, and this **** thing is already at 15ppm. (30 drops, using 10 mL sample) Should I just stop and say it's too high?
    22,551
    No you shouldn't stop. Keep going until the sample turns clear no matter where that is.
    Here's where I'm at so far, but at another question:
    26ppm FC
    .5ppm CC
    7.2ph
    TA is now over 1400 and it's not turning red, keep going as well?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    For the TA, what size sample did you use and did add the R-0007 and the R-0008 before doing the R-0009 drops? What color did it turn before adding the R-0009?
    25mL sample size, and it turned light green when I added R-0008.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It appears to me that something isn't right. Does it change color at all or stay green as you add the R-0009?
    22,551
    Did it change color at all from green when adding the R-0009?
    Linen beat me but we're asking the same question.
    I can try it again if you guys want. I filled it to 25mL, added 2 drops of R-0007, nothing happened (expected). Then I added 5 drops of R-0008 and it turned a greenish color. (expected). So now I was at the point of adding the R-0009 expecting it to turn red, but it's just a yellow, pale color after 140 drops. Eeek. 140 drops.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    So it turned yellow? Then when it turned yellow is your TA. It is likely your high FC is causing the test to bleach out and indicate yellow instead of red. You can reduce this by adding more R-0007 at the beginning. See: http://www.troublefreepool.com/exten...1.html#p206395
    Thanks. I'll do it again but this time record drops of when it turn yellow. That was much, much earlier than 140 drops.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, keep adding drops until the last one cause no more change in color.
    Here are the results:
    26ppm FC
    .5ppm CC
    7.2ph
    25 CA
    450 CH
    60 CYA
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The ph test is not valid at FC levels above 10 ppm. Have you adjusted ph while above 10 FC?
    I assume "CA" above is TA? Then it is low. For now, I would adjust it up to 60 ppm using Baking soda, then allow your FC to drop below 10 ppm and recheck TA and ph. Use PooMath for your chemical addition calculations: http://www.troublefreepool.com/calc.html
    I haven't done any adjustments whatsoever. I did stock up on shock and chlorine tablets though, but haven't used anything.
    Sorry about that, yes, CA should be TA. Thanks for the suggestion on it, I'll go out and buy some tomorrow. How long should it take for my FC levels to drop? It's been nearly over 3 weeks now with elevated levels since the super shock. Is that normal?
    We haven't swam in it though, and even had a couple of crazy rain last week. I figured it'd drop then, but it hasn't.
    What I reported isn't weird? My local Texsun pools gave me the impression that my pool was toxic.
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by casastevo
    Is the pool covered? If it is then take off the cover...this will allow what sunlight you are getting to help remove some of the chlorine. While you are waiting, I would perform a Overnight Chlorine Loss Test (OCLT). See: http://www.troublefreepool.com/pool-...rnight_fc_test
    Well 26 ppm FC at your cya level (60 ppm) is equivalent to about 1 ppm FC at 0 cya in terms of the "disinfecting chlorine" level. 1 ppm with 0 cya would be common in a public swimming pool. Most pool stores are clueless about the chlorine/cya relationship. See: http://www.troublefreepool.com/pool-...ater_chemistry and http://www.troublefreepool.com/pool-...ya_chart_shock
