Results 1 to 7 of 7
Thread: Do I need to move my heater indoors for winter?
    Hi All, looking for some help on whether or not I need to take my Heater off the gasline and store indoors for the winter?
    I live in Cleveland, plenty of snow during the season, I disconnected the water lines from the pooland blew air through the intake to push some water out... im sure its not all the water
    Having an issue getting the stubborn connector on the gas line to budge... wondering if I should just leave it... will it hurt the heater? I store it in an unheated garage during the past winters...
    Thanks
    Dan
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    22,551
    Re: Do I need to move my heater indoors for winter?
    I don't ever remember reading where people store their heaters indoors, so it's obviously not a common thing. Did you remove the drain plug(s)?
    If you did, I wouldn't worry about bringing it in.
    Jun 2012
    western NY
    1,560
    I just drain mine. It is fairly self draining anyway once I unhook the unions from the inlet and outlet. I used to throw an old grill cover over it for the winter. The last couple years I have not done that. Last year, I had an old piece of 1/2" plywood that I put on top of it. It kept the snow off of it and did not allow any buildup around it.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    I did remove the drainplug that is located directly under the in/out header (I have a raypak 130k BTU Nat gas heater)
    so I don't have to worry about freeze damage from any water remaining inside? or should I do something to make sure its more completely drained?
    sounds good to me... I'll find a cover for it and be happy not to move it again!
    I should also note I have two locations where I turn off the gas... one just befoer the joint that's stuck and one by the house and meter (On the dedicated line out to the heater)
    22,551
    You can try blowing it out a little more, but I suspect that it's good enough.
    Jun 2013
    SpringHill FL
    415
    You will be fine just draining the lines and the drainplug. Did it for 10years in Ma. No issues
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
