Results 1 to 8 of 8
Thread: Using Shop Vac to remove water from winter cover
    ArnoldNagy's Avatar
    Jun 2012
    Ontario, Canada
    9
    The search returned way too many results that were all about blowing out lines for winterizing. My question is, can I use a Shop Vac to take the standing rain water off of my Winter cover? My wife came up with the idea and I can't think of a reason why it wont work, but I could be missing something.
    ~Arny
    27' Round, 16,500 gal, AG, installed July 12, 2013.
    Splapool 1HP pump, Distinction 20" sand filter 200 lbs, Feherguard solar cover & reel.
    Titan III Heat Pump.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Using Shop Vac to remove water from winter cover
    You can, and I've done it as well. You're just limited by the size of the tank. In your pool, 0.5" of depth is 175 gallons. You just have to be willing to do a lot of vacuuming and emptying. You may find the using an old piece of hose and creating a siphon may work better.
    22,537
    I use a hose to siphon the water off ours. If it were me, I'd use the shop vac to start the siphon and let it naturally siphon after that. That, of course, assumes that your pool isn't buried and there's enough slope for a siphon to work.
    I use a trick to get the siphon started each time in our pool. Once I get the siphon started, I lay the end of the hose up on an 8" block and let it siphon until it breaks the siphon. That way there is a good bit of water left in the hose and all I have to do to get the siphon started next time is lay the end of the hose on the ground and it self starts. Once it starts, I lay the end back up on the block. There's the added benefit of being able to see if the hose is siphoning from a distance also.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am not following bama...where is the block placed? On the rail?
    ArnoldNagy's Avatar
    Jun 2012
    Ontario, Canada
    9
    I think for this to work the block has to be placed in Alabama
    ~Arny
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by linen
    On the ground. Leave the hose 8" off the ground and it won't drain completely so it will be easier to start next time.
    22,537
    Both Arny and JT are correct!
    It works best in LA (lower Alabama) where it doesn't freeze for days on end. And by raising the end up 8" off the ground, the hose won't completely empty, so it's easy to start the siphon again.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I get it now ...Alabamians, to smart for there own good
