Results 1 to 12 of 12
Thread: Solar install couple quick questions
    Jun 2013
    SpringHill FL
    415
    Ok so i purchased a sunheater brand solar array. The instructions show a horizontal install. Would it be more efficient to install the panels vertically?
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    38,262
    Re: Solar install couple quick questions
    What is the size? Where are you installing it? How is the water routed through the panel (inlet and outlet on opposite ends or the same end)?
    Jun 2013
    SpringHill FL
    415
    It is a 4 panel 2'x20' 1 1/2" headers full flow through designed to be plumbed any and every possible way. I am installing it on my south faceing roof full sun 10 hrs a day. My only question is would it make it more efficient vertical as opposed to horizontal? (Any tips from previous installs are always welcomed and appreciated)
    Nathan
    mas985's Avatar
    Pleasanton, CA
    11,737
    In your location, horizontal is more efficient because during the day in the summer, the sun spends more time above 45 degree elevation than below.
    Mark
    38,262
    How steep is the roof?
    Ideally you want to run one direction through all the tubes in parallel, not one way in some and then back in others.
    I have no experience with the 20' panels, but have seen some pictures where they sag when horizontal on steeper roofs. Whether horizontal or vertical should not really affect the efficiency.
    Jun 2013
    SpringHill FL
    415
    Its a 4/12 pitch and the sag was part of my concern also
    Nathan
    mas985's Avatar
    Pleasanton, CA
    11,737
    The incident angle of the sun greatly affects the efficiency of the panels. Normal incidence has maximum heat transfer. Tangential incidence had minimum heat transfer.
    Mark
    Jun 2013
    SpringHill FL
    415
    *clarification by vertical or horizontal i refer to accross the roof from side to side or down the roof from bottom to top*
    Nathan
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Mark, I suspect they have little need for solar heat in mid summer in central FL, instead the peak solar incident angle for fall / winter is probably a bigger issue.
    Ike
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by FamilyGuy
    Ok, sorry, the original post made no mention of a roof install. Then I agree, there will be little difference in efficiency.
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Somewhere I have read (maybe in my install manual) that the 2X20 panels should not be installed vertically due to their construction and the potential weight of the panel once filled with water. I will poke around and see if I can find it.
    Jun 2013
    SpringHill FL
    415
    Thanks for the responses guys I appreciate your feedback.
    Nathan
