Thread: Is there a trick to installing the last top seat?
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We received the missing upright today and went to put the last top seat on the pool and the rail is about an inch too short. Is there a trick we should know about or do we push the wall it until it fits? So frustrated!!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    Casey's Avatar
    SW PA
    10,450
    Re: Is there a trick to installing the last top seat?
    If you screw them all down before the last one is on, it will prevent them from fitting. Try to loosen the screws and tug a bit and once they are all on, tighten down.
    22,551
    It's like Casey said, You leave all of them loose until you get them all on. You may have to go around the pool and fudge each one a tiny bit to get them all to line up and fit correctly.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    There's not actually screws. It's a resin matrix. We ended up breaking 4 pieces and had to reorder. Now we're emptying again and calling the pool guy back. 350 bucks later grrrr
