My pool is having water leaking issue since we purchased the house in Spring. It is getting worse as time goes by and I have tried to replace the gasket for multivalve to save water from draining down through the valve. It appears to have nothing to do with the leak. I am planning to drain the pool to work several maintenance including patch several plaster spots and fix missing tiles. Is there any good way to locate the leak? What might be most likely places for water to leak?
another related question is for the missing tiles - I am planning to use either stone or something similar to replace missing tiles on the jacuzzi, is it a normal practice or will it look ugly? what might be the best replacement for the whole top tiles for Jacuzzi?
Thanks and I always appreciate all your help!
Dave
Dave
