Thread: Tear in Vinyl Liner on side at water level...
    We just discovered a tear in our vinyl liner (17x35 Oval). It is approximately 6" long - it is maybe 4" from the bead lock at the top. Could we patch this or should we replace the liner?
    Our pool was installed in 2001, never had a leak.
    April
    Vinyl IG, 17x35 Oval, shallow end 4ft, deep end 8 1/2 ft, diving board. Installed July 2001. South Carolina
    Vinyl IG, 17 x 35 Oval 18,500 gallons with diving board installed July 2001. Hayward S200 Sand Filter, Hayward 1 1/2 hp pump, Chlorine, Nature 2. Shallow end is 4ft and 8 1/2 ft in South Carolina
    30,432
    Re: Tear in Vinyl Liner on side at water level...
    That should be pretty easy to patch. Patch kits with enough clear vinyl for that size are readily available at many websites.
    Google "vinyl liner patch kits"
    If you have steps, then you might have the section of liner that was cut out for the steps. If you cut a patch from that, it should match pretty well except for being new vs faded.
    Support the site
