Results 1 to 10 of 10
Thread: Skimmers always clean
    Aug 2013
    Mcallen, TX
    39
    I've noticed that my skimmers don't really collect anything. Before today, the main drain and both skimmer valves were completely open. I decided to close the main drain pipe a little to see if it would make a difference. I did notice a little more current in the skimmer area, where before there was none. Both skimmers were still pretty clean. Any advice on how I can make sure everything is working correct. I know that that stuff is collected in the filter because i still have to backwash my filter and it looks dirty when I do. The thing is that I regularly see stuff floating on top of the pool and baskets are clean.
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    Aug 2013
    Mcallen, TX
    39
    Re: Skimmers always clean
    Also, I've noticed that my filters pressure reads about 10 after it was cleaned. The gage has an arrow at 20 to start and 30 to backwash. Would that have anything to do with it?
    38,284
    You can turn the arrows on the gauge ... the idea is to point the one at the clean pressure and the other would indicate a 10psi rise as time to backwash ... BUT ... WE recommend that you backwash when the pressure rises 20-25% over the clean pressure. So, you should backwash before you reach 13psi. You can still point one of the arrows at 10psi to remind you what the clean pressure is, or point it a 13psi to remind you when to clean ... up to you.
    With 3 suction lines open, it is not surprising to me that you had little skimmer suction. You may actually find that you get better skimming with only one of the skimmers open (the one on the downwind side) and maybe the floor partially open for circulation (although this is optional). You just have to play with them to see what works best.
    You should also check to make sure that the skimmer weirs (doors) are working properly. If they are missing, sticking, or waterlogged, then you won't get proper skimming action.
    Support the site
    Aug 2013
    Mcallen, TX
    39
    This may sound dumb, but are they supposed to be opening when people aren't in the pool. I've noticed that when we are swimming they do fling open to allow water in but I don't think I've ever seen them open with just the pressure in skimmer
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    Where is your water level in relation to the skimmer opening?
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    30,419
    Jeetyet makes a good point.
    Assuming your water level is roughly halfway up the skimmer opening, I would suggest closing down the main drain until you get enough flow through the skimmers that the weir doors lean far enough inward to allow water to flow over the top.
    It'll take a bit to get it right but that should maximize your skimmer capability.
    On my pool, even with the skimmers functioning correctly, I still don't catch as much as I'd like so I don't think you can ever get all the debris but it sounds like you can improve them with some flow adjustments.
    Oct 2013
    29
    check the make sure the skimmers aren't clogged or your impeller
    Aug 2013
    Mcallen, TX
    39
    Thanks for advice, partially closed main drain, actually almost fully closed and left both skimmers open. I Actually saw stuff in the baskets this afternoon!
    Oct 2013
    29
    there ya go! winner winner... just make sure you don't hear your pump "struggling" or your pressure on the filter drop a little... that means the pump is cavitating from not enough water, if not youre good to go
