Results 1 to 7 of 7
Thread: First time closing, two quick questions.
    May 2013
    Taylorsville, KY
    27
    I'm closing my pool for the first time. I have the cover on, pump and filter disconnected from each other. Water drained to below skimmer and return. My questions are:
    1. Do I need to plug the return and skimmer or anything?
    2. I know I need to store the pump inside, but do I need to store the multiport valve? Also, if they do, can I buy the plastic wrench that came with it? I broke mine in half just now trying to unscrew the valve. Its an ecco (waterways) sand filter.
    Thanks for the help.
    And by the way, this site is great! I had zero problems with my first summer owning a pool. Daily bleach and testing and I never had to do anything else to the water!! Many comments on how crystal clear the water was!
    24' Round AGP, 13,500 Gallons. 19" Ecco Sand Filter, 1.5 HP ecco pump.
    Re: First time closing, two quick questions.
    I leave pump, motor and valve outside every winter and have had no issues.
    24,000 gallon ig fiberglass pool
    1 hp hayward pump
    hayward sand filter (250 lb)
    madisonville, ky
    i've never stored my filter, pump, or hoses indoors for the winter. No problems thru 3 winters. I do wrap a tarp around all of it though to shield it from the elements though.
    14,000 gal 24' AG, EcoKleer 1.5hp pump, 26" EcoKleer sand filter, Perma Salt (FML)
    22,553
    Is your pool hard piped? If so it may be a good idea to blow out the pipes, but since it's drained below the skimmer and return I wouldn't worry about plugging them.
    If it is plumbed with hose just unhook the hoses at the pool.
    Storing the pump inside is probably not needed where you are, but it's a good idea if you have the room for it, and it definitely won't hurt anything.
    I don't know if the multiport has a "winter" setting. If it does just put it in that position and if it doesn't I'd rotate it through all the positions and then leave it filter or leave it between two positions.
    May 2013
    Taylorsville, KY
    27
    Thanks for the replies! The multiport does have a winterize spot, which is what it is set at. And it is not hard plumbed, so I just brought the two hoses and pump in.
    38,521
    I did not see it mentioned, did you drain the water out of the filter?
    May 2013
    Taylorsville, KY
    27
    Sorry, yes I did drain the filter and left the plug off (put it in the pump basket)
