Results 1 to 7 of 7
Thread: what if I dont close pool? Snow / Ice
    What if I don't close my pool? What happens with snow and ice? Im in Tulsa and we get both.
    Oklahoma
    30X20 Gunite pool completed in July 2013
    22,550
    Re: what if I dont close pool? Snow / Ice
    You'll have to keep the pump running whenever it's freezing. You'll also have to keep the water level down whenever you get snow. How hard does it freeze where you are?
    Tulsa Oklahoma..we get ice more than snow
    Oklahoma
    mas985's Avatar
    Pleasanton, CA
    11,737
    Does the pool water freeze at all? How thick does it get?
    Mark
    its a brand new pool so Im not sure. I know I would have to run pump when its below freezing..
    Oklahoma
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by thelorib
    Not necessarily. We regularly get below freezing air temps during the winter and sometimes down to 20F but it is usually not long enough for the water to freeze in the pipes. So that is why I asked about the water freezing. If you have more than 8 consecutive hours of below freezing air temps, there is a higher chance of freezing but instead of running the pump, you could drain the pad equipment for a day or two and save a little on pump electricity costs. The underground pipes take much longer (days) before they will freeze. However, if the surface water starts to freeze, you will need to protect the skimmers from cracking. Another trick to prevent freezing of the equipment is to tarp it and put an incandescent light bulb (i.e. heat source) under the tarp. So running the pump may prevent freezing but there are other options as well. However, if you have days of constant freezing temperatures, then you are better off closing the pool.
    Mark
    thank you!
    Oklahoma
