Thread: Nailing in Deck O Drains?
    We are having our concrete stamped decking poured this week and the PB is using Deck O Drains where the poured deck meets up with the house and where it will meet up with the existing concrete patio. They have prepped the forms and I've notice that they have NAILED the Deck O Drains to the house and patio using wooden stakes every few feet. Is this correct? Why would you nail through something that is supposed to wisk water away from the house? To me, all these nail holes directly thru the drains are just going to invite water to seep under the concrete decking.
    Am I wrong to be concerned here? What is the correct way to adhere/hold the deck o drains in place while pouring concrete?
    Thanks!!
    30K gallons, 18x36, Intellichlor IC40 SWG, Sand filter, Intelliflo 1.5 HP, TF 100
    30,426
    Re: Nailing in Deck O Drains?
    I don't see a huge problem but you should address it with your PB and get the reassurance you need.
    Apr 2013
    Sacramento, CA
    2,769
    You don't attach pictures so I can't tell for sure but if you go here:
    http://www.wrmeadows.com/pool-deck-drai ... ge-system/
    That is apparently how the manufacturer recommends installation.
