Thread: Cover sunk into AGP during storm, can I leave it til spring?
    Not sure where to put this but I had closed my pool. everything crystal and done according to Pool School. Then we had 70 mph winds through our valley and pool is covered in leaves on bottom as cover blue into pool! I do plan a drain and refill for next year now, should I just leave as is as it is too darn cold to get in and try to get cover off bottom of pool. The flotation tubes are still there tied around the sides but those are going to come out and be put up. I do not want to drain the pool the rest of the way now as it is too cold and the ground is saturated from a week of heavy night rains, still raining now. I was literally blown away when I saw my cover flying up and down which then broke the clips I used to hold it on the to sides. Before I could control it it sunk. I did not have the strength to contain it at the time and let it just sink down in it's misery and mine.
    Will this be an issue through the cold northeast winter? I sure hope not as I believe this is where the cover will stay. I did drain the pool 40% down.
    ProSeries Above Ground 20x4 Sand filter 1 hp
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cover sunk into AGP during storm, can I leave it til spr
    It will be a mess. There is a chance that the debris in the bottom could leave permanent stains or at least ones that may be very difficult to scrub off.
    Essential Links:
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    I get leaves under my mess cover and I just leave it till spring. If you keep the level of chlorine high and use a brush, then the stains do come off and its fine. That has been my experience anyway. I done get a huge amount of leaves, but some is always going to get under my mesh cover for my in ground pool.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Thank you. I think I am just going to leave it, drain in the spring, bleach and clean and then refill.
