Thread: Infusion Venturi Eyeball Replacement - kiss4afrog
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    I have created your own new thread so it doesn't confuse responders and readers.
    Anyone with any experience using the Venturi eyeballs, good or bad ??
    I'm thinking of adding one or two for the same reason.
    Solar Blanket, Well Water, Borax Added. 76
    Feb 2013
    Yukon, Oklahoma
    220
    Re: Infusion Venturi Eyeball Replacement - kiss4afrog
    I purchase two of the venturi eyeballs when I retrofitted my Intex pool with a "real" skimmer return. I have two of these, one at the "normal" Intex location and another, lower, about the same height as the Intex round return.
    Having an Intex setup I feared the pump would not "flow" enough water to get good venturi action so I used a Dremel to expand the inner part of the Venturi return to exactly what the plastic molding was. So, yes I feel I get more flow and after first starting the pump, boy did I ever get great venturi action from these eyeballs. With hard plumbing and an Intex 2650 filter pump I don't have a whirlpool, but you can float round the pool in a blowup doughnut in about a minute and a half due to the movement of the water.
    If I had a real hayward or Pentair pump on this pool, I know I would not have needed to dremel out the eyeball inner piece. I had wanted these to mainly move my water better than a regular eyeball to better distribute heated water around the pool. Last year, the further away from the returns you were, the cooler the pool was.......now, very little noticable temp difference around the pool. Mind you this is using the same heater as last year on a smaller pool with partial hard plumb.
    Effectiveness for water movement cannot be understated with these eyeballs cannot be understated. Particularly with hard plumbed Intex pool. If/when I move to bigger pool or "real" AGP, I will use these for return. These things keep the water moving.....
    Bob E.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Safetybob
    Did you compare the flow before dremeling them out? In theory the water velocity (and the venturi effect) should be higher with a smaller outlet.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have one I installed to help with my deep end water circulation last, and it seems to have helped avoid cold water sinking in the deep end so much (I don't have a deep end floor drain)
    Ike
    Feb 2013
    Yukon, Oklahoma
    220
    Linen, no I did not do the check before attacking the jet with the dremel. I need to look around to see if I have a spare unaltered one here at the house. Good point that the higher velocity of the fluid should result in noticeable increase in venturi effect.
    I can just report that the flow is VERY significant using hard plumbed Intex 2650 filter pump with the jet dremeled out. I can't imagine how powerful it would be with a 3/4 HP Hayward pump.....
    Bob E.
