Results 1 to 9 of 9
Thread: Pentair filter\DE dust coming out...Just a mess!
    Oct 2013
    Central Florida
    4
    Saved $85 cleaning my own filter. My husband helped. We watched the video and thought we did great. But, now we have DE coming straight back out the jet streams and no water showing in the spy glass. Did we put it back together wrong? It had none of these issues before we took it apart and cleaned the grids. We did forget to leave it on backwash while we cleaned it but, that left little dust in the pool., it's actually coming out the jets now. Also the spyglass always had clear water showing in it and has none now. Please tell me something....It's cloudy and ugly!! Thank you! Please tell me what i can do.
    38,537
    Re: Pentair filter\DE dust coming out...Just a mess!
    Welcome to TFP!
    What setting did you have the valve on when adding the DE? Did you have an o-ring on the internal pipe? As long as all the grids were seated in the manifold, it should be together correctly.
    Also there is only water in the site glass when in backwash mode.
    May 2013
    NJ
    114
    This may be far fetched but it sure sounds like you have the valve set to re-circ. This bypasses the grids and will send your de directly back to the pool. It should be set to filter.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    Oct 2013
    Central Florida
    4
    It was on filter when adding DE. Always on filter when not doing a backwash. Thinking i have time now today to take it back apart as i had a thought about putting the manifold back on and when i did it was horrible hard to re align and wonder if i ended up putting the wing nut back on without having it seated well enough to totally close all the fittings......if i'd left even a slight in balance and it wasn't totally sealed in place all around that would perhaps make the DE come back into the pool, no?? I know now that i'll put the pipes in one at a time all the way around rather than just sit the manifold on top of all of them and throw the wing nut on. Hope i have'nt cracked the manifold. If it's not put on the pipes correctly. Might that be why the DE is coming into the pool?? No choice but to start over and be more diligent and patient. Right.?...I did do a backwash and the sight glass is crystal clear water.......Can't think of anything else that could've gone wrong...all parts are in lovely shape and grids perfect....gotta be the manifolds off kilter or loose...right...?? Thanks again.
    30,432
    Yeah, I think you are on the right track to re-seat those grids.
    Oct 2013
    Central Florida
    4
    Is it ezier to put the manifold back on outside the drum rather than inside?? I did it while back in the drum...I feel this messed it all up.
    Oct 2013
    29
    carsangels... the best way to do it is re-asseble everything upside down.. turn the manifold over and line up all your grids inside of it (paying attention to the where the small grid was) once you have done that take the bottom piece with the rod still in it and then line it up where the grids go in it's slots paying attention to the opening for the 90* elbow to be lined up with the opening on the top manifold... once it's all together good hold both the top and bottom of the assembly and turn it slightly so you can put the nut on the top of the manifold to hold it all together... also when you take it apart today check for torn grids because DE coming back in will happen if you have torn grids, also check for hairline cracks in top manifold. also, take everything OUTSIDE of the tank and take it all apart, then put it all back together, LUBE up the oring thats on the 90* inlet pipe and slide it back in.
    Oct 2013
    Central Florida
    4
    Thank you guys sooo much!!! I finally started all over, following ur advice & tips along the way. The 2" oring was worn therefore not allowing the manifold to seat properly. I'd also tried to skip out on the lube process (dumb idea!) So, for the price of $5.95 I got the oring + lube. I now have a georgous, sparkeling pool!! Plus the knowledge to do it again next summer! But, b4 I even begin I'll get the 1.99 oring + 3.29 lube!! Now, I may need help w/the heater soon!! Thanks again!!
    Oct 2013
    29
    shouldn't have to replace the O ring again next year... anything you remove the manifold always re-lube the O ring
