Thread: Replacing my DE filter
    dgator86's Avatar
    Jun 2013
    South Florida
    6
    Hello all,
    I have made the decision to replace my DE filter with a cartridge filter system. The pool is 16,000 gallons. I have seen threads about turnover rate as well as filter square footage and I can't quite get an answer out of all of it. The house was a foreclosure, the filter is old and the filter media keeps on ripping. The pool is in a screened in porch so I just don't see a reason to have "superior" filtration.
    So based off of what was said, what would you recommend?
    20,000 Gallon, .75 hp single-speed pump, Stainless steel DE filter, Caretaker-99 in-floor cleaning system
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Replacing my DE filter
    Welcome to tfp, dgator86
    Either one (or sand) will work fine for you. For your 16000 gallon pool, we would recommend as minimums:
    • Cart: 240 sq. ft.
      DE: 44 sq. ft.
      Sand: 3.0 sq. ft.
