Results 1 to 9 of 9
Thread: got it working, need help with balance
    Jun 2013
    Palos Heights, IL
    10
    ok, I got my hot tub working after having circuit board issues. Now trying to get it balanced. By no means have I figured out the calculator, so admit am confused. Here are my readings and what the calculator says.
    FC= 5ppm
    TA=70
    CH=270
    CYA=90
    calculator says to add .3 oz or Muriatic acid and 2.8(weight) or 2.3(volume) baking soda, where I am confused is the target goal, it seems I'm good on that. Should I still add anything? I'm also not 100% on how many gallons it is, I entered it at 400 gallons, it maybe less, can't find a capacity tag on it..Thanks
    24' abg approx 48" deep. Sand filter(unknown brand) possibly hayward pump..details to be corrected later..Sunsetter hot tub approx 7'x7'x40"
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: got it working, need help with balance
    How are you testing (what kit are you using)?
    Your cya is very high, high enough that you may want to consider draining and refilling with fresh water. Did you follow the "dichlor than bleach" procedure?: http://www.troublefreepool.com/how-d...ol-t10095.html
    What is your current ph?
    I would not raise you TA much since hot tubs tend to drift up in ph due to the aeration and raising the TA will only exasperate that.
    Jun 2013
    Palos Heights, IL
    10
    Knew I left something off, PH7.8, using the tf 100 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by kevin134
    Great!
    With your high cya, I still think I would do a drain refill...otherwise you probably want to maintain a FC level of 5-6 ppm between soaks.
    Jun 2013
    Palos Heights, IL
    10
    Anything I could have done to cause high CYA?? Just hit it with dichlor yesterday, and not doing the dichlor bleach thing ...yet... doing bbb for the pool and it was my best year with a pool to date, only algaed up once and that was couple days ago, treated today and already looking clear...gotta get that thing winterized next couple days but keeping hot tub open for winter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Did you fill it with pool water?
    Cya only comes from three sources: trichlor (usually pucks, sometimes granules), dichlor (usually granules), and cya (aka stabilizer/conditioner...usually granules, though you can by a liquid version that is more expensive also).
    Jun 2013
    Palos Heights, IL
    10
    Filled from garden hose, not from pool. Thinking went to heavy with dichlor, and am using a non chlorine shock..
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    14 ounces by weight (or 15 ounces by volume ~26 tablespoons) of dichlor would raise a 600 gallon tub to ~90 ppm cya...but your FC would also be 97 if you added it all at once. Do you think you added that much?
    Jun 2013
    Palos Heights, IL
    10
    Nope, maybe need to retest in morning.. thinking now may have messed up test based on that
