Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Water started flowing yesterday
    Jul 2013
    Mississippi
    17
    Hello and thanks for your time.
    Just started our pool up. First test shows after one night of running
    FC- 10
    Cc-0
    Ph-7.1
    Ta-20
    Ch-20
    Cya-0
    Added borax 44 oz as per pool calculater
    And 5 lbs of baking soda.
    Now waiting for another test. How long should we wait to test ?
    Oh pool temp is 84. Any suggestions appreciated
    Thanks brent
    Large lagoon vinly liner pool with straight wall side with 28x14 raised fiberglass tanning ledge with two 30" spill overs six larimars and four bubblers. 35000gallons.
    2- 1 1/2 hp Hayward tri-stars,pro logic plus t-15 swg, 400000 Hayward natural gas heater, Cartridge filter.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Water started flowing yesterday
    You do intend to add CYA as per the requirements for your SWG--------correct? We recommend 60 to 80. You can retest what you have now in a few hours with the pump running of course.. Good sized pool----I'd give it time to mix well. Keep an eye on your PH.
    Jul 2013
    Mississippi
    17
    Where do I get cya? I'm out in the country.
    30,421
    You can order online or any WalMart, HD, Lowe's, etc.
    Get some sooner rather than later and let your FC dift back down to 2-4 ppm until you get the CYA in there, then bring it up to 3-5 ppm.
    Apr 2010
    East Texas
    9,602
    We charge posted pictures for our advice ya' know!
    Jul 2013
    Mississippi
    17
    [attachment=1:33x5iokw]ipad pics 095.JPG[/attachment:33x5iokw][attachment=0:33x5iokw]ipad pics 096.JPG[/attachment:33x5iokw]
    Jul 2013
    Mississippi
    17
    What is the CYA product called and what department in walmart would i be able to find it?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Bainsworth
    This is cya you can get at walmart: http://www.walmart.com/ip/HTH-Stabil...ioner/17043638
    Jul 2013
    Mississippi
    17
    Thank you
    Apr 2010
    East Texas
    9,602
    Paid in full. Nice pool!
    Jul 2013
    Mississippi
    17
    Ok. It's been a few days now and here is my stats
    Ph 8.0
    FC 3
    Cc 0
    Ta 80
    Ch 120
    Cya 35
    Not sure which should I work on. Pool is nice looking. Don't want to cause problems. What would you guys do next.
    Thanks Brent
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What pool surface do you have?
    30,421
    Have your read "The ABC's of Pool Water Chemistry" up in Pool School?
    That's the place to start. It will give you the normal ranges to stay within and will also explain to you why what you are testing is important.
    38,290
    Yup, read up in Pool School.
    Assuming your SWG is active, the CYA is still much too low.
    And your pH is too high.
    And depending on the pool surface, the CH could be too low.
    Jul 2013
    Mississippi
    17
    Vinly liner. And yes I have read pool school, but it will take several times through the school before all this Greek stuff sinks in my solid thick headed skull. Lol. I'm guessing cya up. And acid to bring ph back down. Just wanted some advice from u guys though
    38,290
    When did you last add any CYA?
    I would get the pH down to around 7.5 or so and then get some more CYA dissolving in a sock in the skimmer.
    No need for the CH with the liner (add that to your signature) ... Oh and while you are in there, we like to keep the signatures to a maximum of 5 lines long. Thanks
    Jul 2013
    Mississippi
    17
    Thanks for the reply. Cya was added a little over a week ago. Ph today is down to 7.4 and I added ch to bring it up. I updated my signature, my pool is a vinly liner but my ledge is a fiberglass one. I figure on adding more cya tomorrow assuming ph is steady tomorrow when checked.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Bainsworth
    How much did you add?
    On tfp CH stands for Calcium Hardness. What did you mean here? Neither Calcium or Chlorine (if by ch you meant chlorine) are used to adjust ph up.
    Treat cya and ph independently. Altough cya is slightly acidic, since is dissolves slowly you will likely not notice it's effects. In addition, you swg will likely be driving your ph up. Also, I would not adjust your ph up until it drops below 7.2.
    Jul 2013
    Mississippi
    17
    6 quart containers of cya was added.
    Ch is calcium hardness that I added to bring it up a little more.
    Ph I did not touch I'm happy with it.
    Thanks for your interest.
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The way your wrote the previous post, I though you were saying you added calcium to raise ph. Now I understand.
    I sounds like you added 6 quarts of liquid cya? Then if your pool is ~12000 gallons (is it?), then your cya should have gone up to 46 ppm and since it was liquid cya, it should have shown up at it's final value after a couple of hours of circulation.
