Thread: Maintenance during Winter
    Fort Worth, TX
    83
    I don't close my pool during the Winter.
    The average Winter high temperature where I live is about 60 degrees. The average low is about 40.
    I assume the water temp would not be above 50.
    Would it make sense to only test and adjust FC and pH about once a week?
    PH is more likely to need adjusting than chlorine as I have a lot of aeration. I have a small waterfall my wife likes to run and a Polaris sweeper that breaks water frequently.
    I don't look forward to dipping my arm, past the elbow, in cold water on a cold windy day.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Maintenance during Winter
    You'll have to see if once a week will work well for you but it could. Don't forget the pH as you mention, but it will be much easier in winter no doubt.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Experience tells me that will cover you. But you know we can always have 95 degrees on XMAS day! Biggest reason I don't close mine. And get yourself a piece of 2 ft. long half inch pvc to avoid that arm dipping stuff.
    Fort Worth, TX
    83
    That a good idea about the PVC.
    Thanks for the tip.
    Thank you both for replying.
