Thread: Fresh linen bleach vs. original
    Mar 2009
    Charlotte, NC
    539
    l
    I picked up some fresh linen by accident is that going to be be a problem?
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Aug 2010
    Dallas, TX
    4,052
    Re: Fresh linen bleach vs. original
    Don't use it. It has additional "stuff" that you don't want in your pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep, just stick with plain, unscented, un-thickened, or detergent type bleaches. Regular stuff is all you ever need.
    Essential Links:
