Thread: Is This Right? (Safety Cover)
    Hi everyone,
    First post, I found this site when I was researching my safety cover purchase. Being new to the safety covers Im not sure if what I have going on is normal or not. My water level is to the low side of what the manufacturer of my cover says it should be (12 to 18 below deck). This is a Merlin Smart Mesh. Whenever it rains I get a puddle in the middle that takes days to drain. Does this look right? It sure seems to have a lot more sag than I expected.
    Thanks
    New Brunswick Canada
    819
    Re: Is This Right? (Safety Cover)
    Yes, its exactly as ours is, but ours doesnt take days to drain. You need to ensure water level is 12 to 18" below the cover, this adds support for the cover.
    Quote Originally Posted by pooladdict
    Thanks for the reply. The water level is at 16". It probably takes more like a day or so to drain most of it but then a small puddle remains for another day. I just thought it would drain out a little faster. In any case I like the cover. It's sure going to make opening and closing a lot less of a hassle.
    819
    And you get the benefits of being able to close earlier then others and open later in spring, provided your water is balanced and properly dosed for winter.
