Thread: What to do while on vacation?
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    We will be gone for a week and the pool temp will likely drop below 52 which means that the SWG will not produce chlorine (according to Pentair's documents). We will have house sitters who will keep the skimmers cleaned out but other than them having to manually dose pool with bleach while we are gone, is there any other suggestions? The other thing that can happen is that we live in an area which we can have 60/38 Hi/Low one day and the next will be 75/45. We do not plan to close or cover pool this winter. We have never added anything but bleach, baking soda and muriatic acid to our pool. We have had a perfectly balanced pool all summer thanks to this forum.
    FC 3
    CC 0
    pH 7.6
    TA 80
    CH 80
    CYA 70
    Current pool temp abt 62
    Thanks for the help.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Aug 2011
    Southern California
    188
    Re: What to do while on vacation?
    Pucks.
    Short term use of one week will not hurt you enough to make a difference.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Pucks can work, just keep track of how many you use. Keep in mind for your 20000 gallon pool, each 8oz puck will add ~ 1.7 ppm cya. With your black liner, I would be very careful if you use a floater, so the it does not "park" near the wall and bleach the liner.
    With that said, I would guess that the only time the swg will shut off is in the middle of the night...is it even running then?
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Quote Originally Posted by linen
    I am only running during the day right now. That is a good point about the dark liner. I wonder if bringing up FC a bit before I leave since FC loss with cooler weather drops quite a bit from what I read here.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Take it to slam level and then have the keeper add a gallon or two of bleach a few days into your trip. With cooler weather your FC shouldn't drop that much each day.
