Results 1 to 10 of 10
Thread: Gizmo
    Gizmo
    Someone give me your experience with using a gizmo.
    I have AG 24' pool.
    AG 24' ( Columbia PL30-6 sand filter), 2hp 2 sp pump, cholorine, Tennessee
    Taylor k- 2006 test kit
    22,542
    Re: Gizmo
    They're great!
    Is your pool hard piped?
    Re: Gizmo
    They're great!
    what do you mean exactly? Husband used PVC pipe and some flexible pipe.
    22,542
    Re: Gizmo
    A lot of above ground pools use hoses to connect the equipmment instead of permanent plumbing. with hoses most people just unhook the hoses and don't have to worry about using Gizmos, etc..
    Re: Gizmo
    this is only our second winter to close pool, last winter we lowered the water level below the skimmer and return jets and unhooked the piping also. just trying to figure out how to leave the water level where it is now.
    22,542
    Re: Gizmo
    A Gizmo and plug is what you need. Just install them and then unhook and drain the pipes.
    Re: Gizmo
    One of those rubber plugs for both return jets? I have those but never tried to use because it is so hard to loosen the eyeballs inside the pool and one has a light around it.
    22,542
    Re: Gizmo
    Yeah, but with the aqualuminator you can't use one.
    Re: Gizmo
    Ocean Blue 980015 LED jet light with 3/ colored lenses is what i have over one of the jets, are you familiar with it? and if so, how would that work with the plug?
    22,542
    Re: Gizmo
    I'm not familiar with that light but I suspect that a normal winterizing plug won't work with it. Do you have the instructions for it?
