Thread: Warm Climates
    Aug 2013
    Chandler, AZ
    125
    Warm Climates
    n00b question here.
    I live in sunny Arizona where the average lowest temperature we see is 45F. Along the same lines the greenery never goes away - some plants lose their leaves but most do not.
    Being in a warmer climate, I'm not sure what to do with my pool over the winter months. I don't have a pool heater but I also don't plan on swimming because I'm a sissy and only like to swim when the water is warm, warm, warm!
    So what does everyone do in the warmer climates that doesn't have a pool heater?
    12.4k IGP 27'x14'x4.5', Pebbletec, Pentair EasyTouch, Pentair Intelliflo VS, Pentair IC40, Pentair Quad DE 80
    38,546
    Re: Warm Climates
    Just shorten the pump run time and maintain the chemicals as usual. The chlorine consumption will drop down a lot as the water cools and there is less sun.
    When freezing weather is expected, just run the pump at night to prevent pipe issues.
    30,432
    Re: Warm Climates
    C'mon, PK and jblizzle, the only thing green out there in AZ is the bottom light in the stoplights and some of the paint at Home Depot! (Sorry, I couldn't resist)
    Back to your question, +1 what jblizzle said. I keep my pool open year round and simply treat it the same as summer. Naturally, the FC consumption drops off dramactically, I have to scoop leaves, and I reduce my pump run time quite a bit but the basic principles still apply....maintain adequate FC based on your CYA and keep your pool clean. Keep your test parameters within the ranges we suggest.
    Aug 2013
    Chandler, AZ
    125
    Re: Warm Climates
    That palm tree close to my pool is half brown and half green.
    With that said, I currently don't have a pool cover - is that worth the cost in any manner? I don't have much plant life that will shed aside from that palm tree that somewhat overhangs the pool.
    Thanks for the comments.
    Aug 2010
    Dallas, TX
    4,052
    Re: Warm Climates
    I do exactly what they said above.
    30,432
    Re: Warm Climates
    You don't need the cover.
