Thread: Teledyne V- Diagnosing No Start Issue
    Split topic from here: http://www.troublefreepool.com/teled...on-t12715.html. Please do not hijack another person's topic. Post new questions in a new topic. --Thanks, BoDarville - TFP Moderator
    Hello I own a teladyne v, just changed the pilot and the main controller. But the heater still don't start. I tried all possible jumpers, nothing, only the pilot works. Any idea what can I do to test further?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Teledyne V- Diagnosing No Start Issue
    I don't but we may have a couple of folks here with suggestions.
    Welcome to TFP!
    Essential Links:
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I don't own the model you have but from looking at the parts diagrams they look pretty similar. Here's a couple of very basic items that can prevent a startup.
    1. Make sure you have a totally clean filter. The heater has a pressure switch that will prevent the heater from running if it senses low back pressure in the piping. This is to ensure the heater doesn't fire when there's no water flow (pump off) or when there's low water flow (clogged filter). Sometimes this switch is set conservatively so that it shuts down the heater even though your filter doesn't yet require cleaning or backwashing. Best bet is to make sure your filter is 100% clean before doing any other troubleshooting.
    2 This may be a peculiarity of my heater, but I noticed the very first time I start up for a season, it takes a good 15 minutes to fire. There is a startup delay function built-in which I thought was supposed to be only 3 minutes or so, but for some reason it's really a long delay on my first start. So if your heater acts similarly, turn it on and leave it that way for a half hour and see if you get startup. If you give up too soon you may not be giving it enough of a chance.
    These are just 2 no-tools things you can do. After that, it would be time to get out a multimeter and take some voltage/continuity readings.
    Good luck
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Are you getting the correct amount of milivolts out of the new pilot?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
