Results 1 to 19 of 19
Thread: how slow can slow be
    Jul 2012
    Whidbey Island, WA
    397
    Hi again
    is cool here in W Washington, a little sun now and then, pool is covered, water is clear
    on 10/2 was using K-2005, diluted pool water 1:4, and found FC 2-3, so then 8-12ppm
    have added no bleach and Rainbow is set to zero, ie closed
    today 10/15 the chlorine test kit arrived from http://tftestkits.net/Single-Item-Tests-c6/
    and returned FC 12 and CC 0
    is it possible that FC has not declined for 13 days?
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    30,431
    Re: how slow can slow be
    No, that's not really possible.
    The problem is likely in your dilution. Each time you dilute the accuracy gets thrown way off so a 4:1 dilution is pretty meaningless.
    Go forward with your new FAS/DPD test and you'll be fine
    Jul 2012
    Whidbey Island, WA
    397
    thank you
    will follow with the new test kit and see what happens over the next days weeks and report
    is kinda fun not having to add bleach / tabs
    maybe I have a spontaneous source of Cl (dead worms, Puget Sound rain, old plaster, deer pee)
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    It's that deer pee that'll do it!
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Jul 2012
    Whidbey Island, WA
    397
    so have new test kit
    10/16 FC 12.5 (10cc, 25drops)
    10/25 FC 12, CC 0, pH 7.6, TA 60, CH 240, CYA 50 (10cc, 24 drops)
    still cool, cloudy, covered
    so in 9 days drop of FC essentially zero
    so am nervous
    is this Ok or
    am I about to see yellow water
    If there are tabs in the feeder, you might get some chlorine from the feeder even with it set to zero.
    Support the site
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Pool is covered and there is no swimming? Combine that with cold water temps and your FC can last a long time since the chlorine is not being used by the sun or organics. It won't last forever, but could last for awhile.
    Also, when you did your previous dilution of 1:4 (1 part pool water combined with 3 parts non-chlorinated water?) your uncertainty could easily have been higher than +/-4 ppm due to the precision of that test.
    Jul 2012
    Whidbey Island, WA
    397
    so the test continues
    pool clear, covered
    weather cloudy cool
    10/16 FC 24 drops 10 cc; CC none
    11/5 FC 24 drops 10 cc, CC none
    will continue to follow
    38,475
    So does that mean 24 drops into 10ml sample so your FC is 12ppm?
    If so, just report the ppm
    Jul 2012
    Whidbey Island, WA
    397
    so the tracking of FC decline continues
    FC was 12 on 10/2 and 9 today 12/4
    so declined 3 in two months
    also
    troublefreepool chlorine tester is cool
    what do I vac up in the winter? leaves worms and one rat, but very little stuff as back wash is very clean
    pH continues to creep up and I bump down with acid every so often (TA 60); why does pH creep up?
    Smykowski's Avatar
    Sep 2011
    3,065
    What's the water temp? As temp falls, the pH will go up.
    Jul 2012
    Whidbey Island, WA
    397
    41 but
    it creeps in the summer as well
    seem to always be adding chlorine and acid (tho not chlorine now)
    30,431
    The pH tends to rise in most every pool. More so in an SWG pool. It's the nature of the beast as the TA slowly outgasses.
    Chlorine, of course, is a consumable item and you will be adding it for the rest of your pool's life.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by engrav
    41 but
    What is your TA? Higher TA will cause quicker ph drift up.
    Smykowski's Avatar
    Sep 2011
    3,065
    41 but
    I'll let ChemGeek correct me if I'm wrong, but the pH changes are for two different reasons. In the summer, temp is relatively constant but pH changes anyways - high TA, outgassing/aeration, the effect of the SWG, etc. In the wintertime, there are no appreciable changes to your pool water except for temp, and the pH is changing because the temp is changing.
    Jul 2012
    Whidbey Island, WA
    397
    end of experiment, how slow can slow be
    FC is now 7, took 3 months to drop from 12
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    With pool covered and cold water temps I think that is good. What is your water temp ?
    Jeff
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by pwrstrk
    Hi
    39
    too cold to put your hand in it, have some shoulder length gloves with liners that crabbers use in AK
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by linen
    [/quote]
    TA is 60
