Results 1 to 10 of 10
Thread: Fencing around pool area
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I learned something tonight about fencing...the black aluminum alloy type...so far, all of my quotes have been in the $35/ft range. A friend who has a fencing company quoted me $29/ft for a "residential" grade fence, or $37/ft for a commercial grade. The difference is heavier duty pickets (5/8" vs 3/4"), 2.5" posts vs 2", and a heavier top rail on the commercial grade. Also, a hidden fastener system is on the commercial grade.
    I didn't even realize, or really think about it until he gave me the options tonight, to ask what 'grade' the other contractors were quoting. I'm assuming "residential" grade though. I checked a neighbors, who had his just done, and it the smaller size. I'm guessing that's more common?
    What do you folks think? At first I didn't think I was getting any type of deal from my friend (since I know him well), but I'm actually thinking I was. I didn't get into negotiation at all yet, just first offer to get an idea. But it sounds like most likely for the same price most others quoted, he was offering me a heavier duty fence. But do I need it? I don't know much about this style fence and how well it holds up. I'm talking about 200' of fence with 3 gates. If I don't need it, I can save about $1500 on the fence.
    Thanks!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    22,548
    Re: Fencing around pool area
    You most likely don't need it unless your AHJ requires it, which I doubt.
    I'd go with the friend, Mostly because he's a friend, and then because he's saving you some dollars!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    AHJ? You mean like the code enforcement or something? I'm someone who always feels bigger and heavier is better. He said it will stand up, of course, to more abuse and hits from things like mowers, but it's like 50/50 in terms of folks picking residential sizing vs commerical.
    22,548
    Yeah, AHJ (Authority Having Jurisdiction).
    There are times when bigger is better, but then there's also probability. What's the chance that it needs to be bigger? How often are you going to run into it with a mower? Also will the commercial grade stand up to a mower running into it that much better than the residential grade (I suspect, not much)? The commercial will probably stand up to a line trimmer better.
    May 2013
    Fort Lauderdale, FL
    423
    I don't think you need heavier material. Think about the typical commercial pool area- kids hanging on the fence, pool chairs banging into it, etc. I'd be more concerned with the finish and corrossion control. If it's good powdercoated stuff, you should be fine.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    May 2013
    North East Ohio
    959
    I had same decision and brought a panel of each over to see. The HEAVY DUTY looked horrid...way to "BIG", just looked odd. I just paid $30 per ft and I thought I got a good deal, yours is a tad better.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Are your fasteners hidden? I do like that about the heavier fence. But not sure how it looks if they are not.
    May 2013
    North East Ohio
    959
    Quote Originally Posted by steveg_nh
    Actually mine are hidden...I am fairly certain you might be able to find "residential" grade that has the clean look. Just ask your friend to look around a bit.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Thanks!
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    So the devil is in the details. That price I quoted didn't include the 3 gates and an arched gate. It was just the pricing per foot for the regular 6' sections. When I added it up, it was closer to the $35/ft. I ended up going with the construction company doing my patio as well. He beat the price, and is doing a better quality residential fence IMO. Hidden fasteners, powder gated, a 6' gate, etc. Thanks for the pointers.
