Results 1 to 7 of 7
Thread: Do you put anything in stored AGP for winter?
    Jun 2012
    Michigan
    154
    I just took down my intex AGP and have it not completely folded up in a shed so it can completely dry out. But is there anything i should spray/sprinkle inside the pool while it sits in the shed through the winter? Like something to stop it from cracking (if it even does that), keep varmints out, whatever other things that could happen to it over a winter of storage.
    Intex 16x48 UltraFrame AGP, included filter pump
    22,553
    Re: Do you put anything in stored AGP for winter?
    Most people just generously sprinkle talcum powder in it and fold it up.
    Jun 2012
    Michigan
    154
    I could definitely do that. Does that just keep it dry? Also, next year when I go to set it up, do I just vacuum that out or will a filter get it when I fill it with water?
    22,553
    It keeps it dry and keeps the vinyl from trying to stick together. Just shake as much out as you can next year and the rest will filter out.
    Jun 2012
    Michigan
    154
    Great, thanks Bama.
    Aug 2011
    Cochranville, PA
    228
    You mentioned varmints. Are mice a problem in the shed?
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Jun 2012
    Michigan
    154
    Never have been with other things but this is my first year storing a pool in there. II'm really not sure what to expect know what I mean
