Thread: Diver Dan / AquaBug /Wanda
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Well the Wanda the whale worked good all summer
    I usually left her on for a few hours and the pool was always clean.
    I never went out and checked her , maybe once an hour
    Well I had an algae issue before we closed , so I was cleaning a lot.
    Know being a little paranoid I was always checking her to make sure everything got cleaned good while I was slamming the pool.
    So my problem
    Wanda kept getting turned on her side????
    I tried shortening the hose and lengthening the hose, but most times when I came out to check on her she would be rolling on her side.
    Anyone else have this issue?
    I also tried to get the hose section to be as straight as possible, I noticed that over the summer they seemed to have a little curl one way or the other , but that didnt seem to help either
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Diver Dan / AquaBug /Wanda
    Tried one of them and had much less success than you on all counts. It always got on it's side and I gave up out of frustration. I thought they were a big PITA.
    Essential Links:
