Thread: Fafco install - substrate?
    Mar 2013
    San Jose, CA
    25
    Hi All,
    I just purchased 12 used Fafco panels and I have an installation question. The Fafco manual says
    "2. Lay down the first panel. Be certain it is straight and square on the roof.
    Simply lay substrate underneath each panel."
    What is the substrate? I can seem to find a reference any where. We have a composite shingle roof.
    thanks,
    Steve
    14x28 Hydra Pools vinyl pool. EasyTouch, my own web interface (Screenlogic died), Intelliflow VF, 3 Pentair GloBrites, Pentair Master Temp heater, Hayward DE filter. 89" fiberglass spillover spa
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Fafco install - substrate?
    Try looking at http://h2otsun.com/ for some good generic installation techniques, they have lots of examples of installations on alternative as well as traditional roof materials. I don't know for sure what they are talking about in the Fafco manual, but I suspect it is some type of rub plate.
    Ike
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Just lay them on the shingled roof. That is how it's down all over from what I have seen. Shingled or tiled roofs, just lay out the panels.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2013
    San Jose, CA
    25
    Quote Originally Posted by ps0303
    That's what I expected. I have seen references to sheet metal placed below the the plumbing where it hits the shingles as a wear preventative.
    I suspect the panels move around a bit as they expand and contract with temp.
    Steve
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by SteveB48
    Steve
    Yes they can wear on the shingles so you would need to put something under certain parts of them to prevent the wear.
    Paul
