Just a couple corrections/comments:
True, but we also advocate opening up a sand filter once a year to clean the sand as well.Davegvg said:Cartridge, and DE require them to be opened up and taken apart to be cleaned occasionally (definition of occasionally depends on many factors) especially in the advent of an algae bloom.
DE filters can certainly pump to waste just like a sand filter if you have a multi-port valve ... mine all have.Davegvg said:De filters can't really filter to waste so if you have a particularly bad dirt infusion from a storm you can't just vacuum the pool - you have to charge and clean the filter over and over again.
You can get huge cartridge filters and many members only clean once a year. I also do not think a TSP soak is required as often as you claim.Davegvg said:Cartridge filters need to have the cartridge out and soaked in a garbage can full of TSP or some other cleaner at MINIMUM once or twice year which if you have spare isnt a big deal- but you cant get really big cartridge filters and if you have a dust problem or high influx of debris like I do- the dream of once or twice a year cleaning goes down the drain and you are inside the filter over and over.
We recommend cleaning any filter when the pressure rises 20-25% over the clean pressure, this should be checked on a higher RPM / high speed. A 2psi rise on low speed could easily be a 100% increase in the filter pressure, so certainly the flow rate will suffer. As mentioned before, cartridge filters had lower head loss as well and thus would allow greater flow rates for a given plumbing setup.Davegvg said:If you are running a variable speed pump and tuning the RPM down to save money a 1-2 lb rise in backpressure can effectively halt the flow leaving you with 2 choices - bump the RPM spending more money and forcing the flow, or backwashing which is a chore on Cart and DE filter. If you are just running a 1 HP pump it will force system even with 10 pounds of backpressure but you arent saving any money on electricity.
Sand filters are certainly the least maintenance, but they are not the only filters that can vac to waste. A simple 3-way valve added before a cart filter can allow the same thing. Once you get to very large pools, I also think it is easier to find appropriately large cartridge filters than it is to find sand filters that are large enough.Davegvg said:Sand filters are a snap to backwash, can vacuum to waste, offer comparatively large surface areas of filtering and a greater degree of sizes, and when filled with zeo type media offer DE, or near DE filtering.
It really is personal preference. They all have pluses and minuses. And we have seen time and again that ANY of the filter types can keep a pool crystal clear.Davegvg said:Been there, done that forever - sticking with a sand filter and zeo style media.
